Cisco ASR Router 1002 power supplies
gscalia01
HI,
I have a question are the Cisco ASR 1002 router power supply hot pluggable?
I have a failed power supply on P0 and i wanted to know if i can replace the faulty power supply without having to power down the router.
Jack
Bilal Nawaz
Yes they are hot swappable.
Make sure you swap within 3 - 5 mins otherwise ASR will power down i think. Also keep eye on the log messages too. It will be fine, I have done it before too.
hth.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
