Cisco ASR1004 + ISG + RADIUS-based shaping
Hello!
I need to configure ISG with RADIUS-based shaping. There are two traffic classes: Internet (class-default) and Local Peering (PEERING-TRAFFIC). Class-default traffic must be shaped with committed rate with contract conditions (from billing via RADIUS, for example 2Mbit/sec), PEERING-TRAFFIC must be shaped with fixed commit rate 50Mbit/sec. I have tried many times and now I have this config (and it works):
Conprol Policy-Map
policy-map type control ISG-L3-ROUTED-CONTROL
class type control UNAUTH-DISCONNECT-CONDITION event timed-policy-expiry
  10 service disconnect
class type control always event session-start
  10 authorize aaa list ISG-RADIUS-LIST password ISG identifier source-ip-address
  20 service-policy type service aaa list LOCAL-SERVICES name L4-REDIRECT-SERVICE
  30 service-policy type service aaa list LOCAL-SERVICES name OPENGARDEN-SERVICE
  100 set-timer UNAUTH-DISCONNECT-TIMER 10
QOS Policy-Maps
Policy Map ISG-GENERAL-POLICY-IN
  Class PEERING-TRAFFIC
   police cir 50000000 bc 1562500
     conform-action transmit
     exceed-action drop
  Class class-default
    service-policy ISG-CHILD-POLICY-IN
Policy Map ISG-GENERAL-POLICY-OUT
  Class class-default
    service-policy ISG-CHILD-POLICY-OUT
Policy Map ISG-CHILD-POLICY-OUT
    Average Rate Traffic Shaping
    cir 50000000 (bps)
  Class class-default
Policy Map ISG-CHILD-POLICY-IN
  Class class-default
User-Authen RADIUS-Attributes
AttributeValue
Idle-Timeout
40
Session-Timeout
180
Cisco-Account-Info
AISG-TRON-SERVICE-TEST
Service-Authen RADIUS-Attributes
AttributeValue
Cisco-AVPairip:sub-qos-policy-in=ISG-GENERAL-POLICY-IN
Cisco-AVPairip:sub-qos-policy-out=ISG-GENERAL-POLICY-OUT
Cisco-AVPairqos-policy-out=add-class(sub, (class-default), shape(100000000))
Cisco-AVPairqos-policy-out=add-class(sub, (class-default, class-default), shape(2100000))
Cisco-AVPairqos-policy-in=add-class(sub, (class-default), police(2000000))
I do not like this multiple “shape”: in parent policy and in child policy. I worry about device utilization. I can’t remove shaping with CIR 100Mbit/sec from parent out policy, because service policy installation failed in this case:
*Jun 19 14:13:00.713:  Cannot attach queuing-based child policy to a non-queuing based class
*Jun 19 14:13:00.713: %QOS-6-POLICY_INST_FAILED:
  Service policy installation failed
And I can’t remove all shaping to parent policy:
*Jun 19 14:14:37.708: SSS PM ERROR: Policy context is NULL or missing action in get aaa author passwd list APITraffic Shaping feature is not supported in user defined class of parent level policy
*Jun 19 14:14:37.716: %QOS-6-POLICY_INST_FAILED:
  Service policy installation failed Traffic Shaping feature is not supported in user defined class of parent level policy
What is the right method in this case? May be I need to shape different traffic in different service? But I can’t define traffic class in RADIUS-attributes correctly.
Thank you!
7 Replies 7
bhumindesai
hi Konstantin Vinogradov ,
have you found any solution for above query.? i do want same solution for my setup..
Bhumin Desai
Hi, bhumin.
Unfortunately I didn't found any other solution. Now I use configuration that I described in the first post. I have some problems with policng, but I think it depends on version of IOS.
, yesterday we have done it as below..may radius config and flow differ.
  • user service = P2P
VendorAttribute   CodeAttribute   Value
DefaultSession-Timeout86400
CiscoCisco-SSG-Account-InfoA1mbpsInternet
CiscoCisco-SSG-Account-InfoA10mbpsp2p
  • service 1 =A1mbpsInternet
Ciscocisco-avpairip:traffic-class=in   default drop
Ciscocisco-avpairip:traffic-class=out   access-group name non-P2P-out
Ciscocisco-avpairip:traffic-class=out   default drop
DefaultService-TypeOutbound-User
DefaultDownload-QoS1Mbps
DefaultUpload-QoS1Mbps
Ciscocisco-avpairip:traffic-class=in   access-group name non-P2P-in
Ciscocisco-avpairsubscriber:accounting-list=PPP-USR
  • service 1 = A10mbpsp2p
DefaultDownload-QoS10mbps
Ciscocisco-avpairip:traffic-class=in   access-group name P2P-in
Ciscocisco-avpairip:traffic-class=out   access-group name P2P-out
DefaultUpload-QoS10mbps
thats all...u just need to assigh service P2P with subscriber & u good to go..this way you can account/charge subscriber for what he/she use at actual.
the only prob m facing is.. m getting 2 sessions for subscribers in AAA server while only 1 in ASR... no other prob at all.
try it..
Bhumin.
Hi, Bhumin.
Sorry if I replying late.
About "Default Download-QoS 10mbps".
Is "10mbps" policy-map's name? Do you have it in your config?
Thank.
Best regards,
Konstantin.
bhumindesai
Dear
N/A
Alex M
Hello!
I have the similar problem, so I've decided to ask it here. I'm working on ISG configuration on ASR 1001x. It works OK, but I need to add a lot of new services with DSCP policies, like this:
policy-map 50m
 class class-default
  police cir 51200000 conform-action set-dscp-transmit af11 exceed-action set-dscp-transmit default violate-action set-dscp-transmit default
policy-map type service 50m-SRV
  service-policy input 50m
  service-policy output 50m
I wonder if I can make ASR download it from RADIUS as a usual service but with parameters. I've read about pQoS in Cisco Guide:
qos-policy-in=add-class(target ,(class-list ),qos-actions-list ) qos-policy-out=add-class(target ,(class-list ),qos-actions-list )
 And it seems that's what I need, but I have some questions:
1) Is it possible to "stick" qos-policy-in and qos-policy-out on service?
2) The Guide said that: "...Parameterized QoS is not supported for IP sessions...". If I send it as service and not as session, is it allowed to use it with IP sessions?
So, I've tried to apply QoS policy on service. it works, service has been applied:
SERVICE-TEST    Auth-Type := Accept
    User-Password == "cisco",
    Cisco-AVPair += "ip:sub-qos-policy-in=isgPolicy",
    Cisco-AVPair += "ip:sub-qos-policy-out=isgPolicy",
    Cisco-AVPair += "ip:qos-policy-in=add-class(sub, (class-default), police(15000000,0,0,transmit,drop,drop))",
    Cisco-AVPair += "ip:qos-policy-out=add-class(sub, (class-default), police(15000000,0,0,transmit,drop,drop))",
    Idle-Timeout =  "600"
But if I change action transmit to action set-ip-dscp(10) then error message "...wrong action set-ip-dscp(10)" appears in debug. Does anyone know how to solve this problem?
