cisco business series 250 bpduguard commands
raanan98
hello everyone!
is there any bpduguard commands in cbs 250 series?
I enabled spanning-tree portfast command without the auto mode, and I want to ensure that the ports are protected.
Mark Elsen
        >...is there any bpduguard commands in cbs 250 series?
          - There isn't , yet the cbs 350 has it ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
according to the guide below, the 'spanning-tree bpduguard' command is available. @Mark Elsen is probably right, as this is the combined guide for both the 250 and the 350 models...
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-250-cli/spanning-tree-commands.html#wp3936785030
                                                            >....is probably  right
@Georg Pauwen This time I am , (despite being married - LOL!) ; however I could verify it by using
                   https://www.cisco.com/c/en/us/support/smb/product-support/small-business/Device-Emulators-Small-Business.html
  and logon to both devices go to expert mode then you can see  that the bpduguard setting is available as a port setting on the 350 and not on the 250.
   The two manuals being together for both models often leads to confusing interpretations ; and or at some points Cisco should better make a note when a feature is not available on the 250 (e.g.),
 M.
       Beauty and terror
      Just keep going
       No feeling is final
