Cisco C1000 switches for NAC solutions
HARIHARAN S
Do the Cisco C1000 switches support for multi-vendor NAC solutions like Cisco ISE, FortiNAC, Aruba Clearpass.
balaji.bandi
the switch support 802.1x - with cisco ISE
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/configuration_guides/sec/b_1527e_security_c1000_cg/ieee_port-based_auth.html
check with the vendor you integrating supported on their matrix.
BB
