Cisco C2960G-8TC resetting to manufacturer
pcfreak49
I have a problem on Cisco C2960G-8TC how can that resetting to manufacturer settings ?
5 Replies 5
Leo Laohoo
You want to set the appliance into default?
Delete the following files:
1.  config.text
2.  vlan.dat
Don't know if you have other useless files but the only thing I want to see is the IOS file/folder.
I see
in
the
flash
that
only
config.text
should be able
to
remove
them?
Can you post the output of the command "dir" please?
how do you mean because there is no reset percies knock on the unit
use the command
delete flash:config.text
this will remove the config, after you confirm use the "reload" to reload the switch. If you get the question, don't save the config.
Thats all...
- Sebastian
