Cisco C2960S-24TS-S Lan Lite switch - running Gig ethernet - or Lan Base needed
paul.dye
I am a little confused concerning the Lan Lite and Lan Base images for the 2960 switch.
I want to use 2960 switches running vlans and gig ethernet to the servers in a cabinet/rack
I have looked at C2960S-24TS-S which runs the lan lite image, but have been asked if we require the Lan Base image.
After searching through the net and looking at cisco specs, i'm confused if the C2960s-24ts-s will run gig ethernet ??
else i was looking at c2960g-24tc-l running base, but is more expensive
c2960s-24ts-s lite lan
www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd806b0bd8.html
base lan
www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Can somebody please verify if the 2960-24ts-s will run gig ethernet using lan lite image
Hi Alessio
Yes i have that link in the original question
This is what confused me
https://supportforums.cisco.com/thread/2064403
Cisco Catalyst 2960 LAN Base switches have several advantages:
• Gigabit Ethernet connectivity in 8-, 24-, and 48-port configurations
Cna you confirm that cisco
C2960S-24TS-S which runs the lan lite image will run gig ethernet
Leo Laohoo
All 2960S models have GigabitEthernet (except the Management interface).
