Help with 6506-E Config
mattoxm.psrc
Visitor
I have a 6506-E with 720 Sup. I am trying to connect a server with HP 550SFP Nic to my 6506.
If I plug the SFP from my server into my 6506 it will not link. When I plug that very same SFP into a 3750 it links fine. Makes me think that there is something I am doing worng on the 6506 Config.
But, If I plug another server using a IBM LAN Card into the same port on my 6506 it connects and works fine so now I am starting to wonder.
Any toughts or suggestions would be helpful.
Giuseppe Larosa
try to add
switchport nonegotiate
in interface configuration on the C6500
it can make the difference in some cases
Hope to help
Giuseppe
Defaulted the config on interface
Entered
switchport
switchport host
Tested connections and I am still at the same point.
Any other thoughts?
Manesh Rajan
I think that interface is configured for non negotiate, so its better to change it to
Switchport mode access
Switchport access vlan 1
no shut
Thanks for the input
I finally figured out today that I had to set the following to get it to work.
speed nonegotiate
speed 1000
Once I did this they started linking correctly.
