Cisco C2960X CPU Utilization is >90%
In Cisco C2960X, CPU utilization is going to >90%
Current Switch IOS version is 15.2(2)E.
Mark Malone
Your hitting a know bug HULC its ion most platforms , you will need to move to an IOS its not in
160 1782793392 158371875 11257 31.25% 35.53% 36.57% 0
Hulc LED Process Cisco Bug: CSCtg86211 - Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X switch Last Modified Apr 06, 2016 Product Cisco Catalyst 2960 Series Switches Known Affected Releases 12.2(50)SE3 Description (partial) Symptom: Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X 24 or 48-port switch. Conditions: The CPU utilization for Hulc LED Process will be in the 6-23% range for the Catalyst 2960 series like 2960, 2960S, 2960X switch models. For WS-C2960X-48LPS-L which is 48ports PoE 2960X switch Hulc LED Process Could reach about 22%-23%. The is seen in 12.2(50)SE03 or later releases. View Bug Details in Bug Search Tool Login Required Why Is Login Required?
The "Hulc LED" process does following tasks: - Check Link status on every port - If the switch supports POE, it checks to see if there is a Power Device (PD) detected - Check the status of the transceiver - Update Fan status - Set Main LED and ports LEDs - Update both Power Supplies and RPS - Check on system temperature status
Last Modified: Apr 19,2016 Status: Terminated Severity: 3 Moderate Product: Cisco Catalyst 2960 Series Switches Support Cases: 235 Known Affected Releases: (1) 12.2(50)SE3
Known Fixed Releases: (0) No release planned to fix this bug Download software for Cisco Catalyst 2960 Series Switches
This cpu utilization is not always in peak, but this is going down and up frequently.
One third of your cpu is hit by that bug HULC 36% , if it wasn't there your cpu would less than 60% from the output you gave which would be normal enough , are you saying when its high other times that's not the process causing it ? if so need the show proc from that time to see what was the cause as its real time cpu traffic
