How to forward a range of ports on Cisco 881?
CSCO12712564
Hello.
We have 3 sites with SIP server in one office and VoIP phones with internal numbers in other two. We've got a little problem with Asterisk server in our local network. Company, who set it up, says, that we need 5060 and 10000-20000 ports forwarded from Internet to this server. I also heard, that on Cisco IOS we can just forward 5060 port, and the router could forward right RTP ports for us. But it wasn't work. Phones in central site (with Asterisk server) worked, but in two other offices people can't hear anything. Also i tried to turn off that feature (no ip nat service sip port 5060). Same result. I also tried this construction :
ip nat pool POOL1 192.168.1.1 192.168.1.1 netmask 255.255.255.0 type rotary
ip nat inside destination list 101 pool POOL1
access-list 101 permit tcp any any range 10000 20000
But i've got the same result. I came into despair and tried to forward those damn ports with static entries, just like they binded on VoIP phones. With some success, two offices can normally have a conversations, but in one office people can hear a voice, but we can't hear them.
My question is, how on Cisco router can we forward a range of ports to internal IP?
I attached config of Cisco 881 (gateway in office with SIP server) to clarify this situation.
Mark Malone
Maybe something like this
ip nat inside source list 110 interface dialer1 overload
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
access-list 110 permit tcp host 192.168.1.36 any range 10000 11800
I think your advice is to give access from host to Internet. And first line in this ACL will give all access to all hosts in subnet 192.168.1.0.  Our mission is to give access from internet to host, on ports 5060 and 10000-20000. Another words, for the Internet host will be available on ports:
205.33.185.35:5506
205.33.185.35:10001
205.33.185.35:11800
And when we try to give access on port 10001 to address 205.33.185.35 we'll go to the host 192.168.1.36:10001
With your solution, for the Internet, when we try get access to port 10001, we will go to the router, with te external address 205.33.185.35. It will not work with Asterisk server.
