CISCO C3750X DHCP issue
Hi All,
I have a CISCO C3750X switch which I have set up VLANs as well as tagging for a trunked port. That all works. I am also trying to set up two DHCP reservations and they are not working. The Windows PC is stating that there is limited connectivity and the IP address it got is completely different. The test PC is a Windows 2003 Server.
The commands I used were:
ip dhcp pool poo1
host 172.22.10.50 255.255.255.0
client-identifier 01UU.VVWW.XXYY.ZZ
I have also tried using hardware-address UUVV.WWXX.YYZZ to no avail.
show ip dhcp pool lists the pool and says 0 subnets is currently in the pool.
Anyone knows what is going on?
EDIT::
I then tried using port binding as according to the this article as follows:
ip dhcp relay information policy removal pad
no ip dhcp use vrf connected
ip dhcp use subscriber-id client-id
ip dhcp subscriber-id interface-name
ip dhcp pool testpool
 network 172.22.10.0 255.255.255.0
 address 172.22.10.50 client-id "Gi1/0/5" ascii
I am still not getting anything.
TIA,
Vlad
Philip D'Ath
The syntax needs to be like this:
ip dhcp pool nas
host 192.168.1.252 255.255.255.0
hardware-address 00d0.b821.9992
Got it to work. The syntax is correct. However for layer three switches to issue dhcp addresses, the vlans must have an ip address. As soon as I assigned an IP address for the vlan in question, it worked.
However, what I want was to have two ports on that vlan to have DHCP. So with the following:
ip dhcp pool dantepciecards
 default-router 172.22.10.1
 lease infinite
 address 172.22.10.51  client-id "Gi1/0/14" ascii
It always assigns 51 no matter if I plug it into Gi1/0/5 or Gi1/0/14
It all works now. I forgot to release and renew the IP address. Once released, it got the new one when I swapped the ports. I wanted it to be port specific so if a piece of hardware fails, replacing it means that we don't have to reconfigure the switch for different MAC addresses
