04-19-2019 06:21 AM
We have four power supplies seated in our catalyst 6807-XL. But we are using only 2 PS out of 4. Is there any way we can have the switch stop monitoring the other 2 PS and stop the hardware alerts we get frequently from the switch onto our monitoring tool?
environmental alarms:
system minor alarm on power-supply 3 power-output-fail (raised 30w2d ago)
system minor alarm on power-supply 4 power-output-fail (raised 30w2d ago)
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: AC high
power-supply 1 power-output-mode: high
power-supply 1 incompatible with fan: OK
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: AC high
power-supply 2 power-output-mode: high
power-supply 2 incompatible with fan: OK
power-supply 2 power-output-fail: OK
power-supply 3:
power-supply 3 power-output-fail: failed
power-supply 4:
power-supply 4 power-output-fail: failed
04-19-2019 07:14 AM - edited 04-19-2019 07:15 AM
I am not sure if there is a way on the switch but you can probably ask the management software vendor to change the setting, so SNMP does not pull all the PSUs.
04-19-2019 10:34 AM
04-19-2019 10:42 AM
Depending on the vendor, you may have to open a ticket with them, so they can look into it. Sometimes, it requires tweaking the backend server to eliminate the alert.
04-19-2019 08:02 AM
DarkPhoenix,
If there is no power cable in the 2 power supplies not being used, then why not just remove them, set them aside for spares and put blanking panels in ? Of course, only do this if you have sufficient power in the remaining supplies for Redundant Mode redundancy.
Cheers,
Scott
04-19-2019 10:34 AM
Thank you. We will try this.
