Cisco C8200-1N-4T Switching
kgera
Hello folks,
We have Cisco C8200-1N-4T, it has 4 L3 ports GigabitEthernet0/0/1-3 and 4 L2 ports GigabitEthernet0/1/0-3
Could you please advise if it's possible to configure L2-domain between interfaces GigabitEthernet0/0/1 and GigabitEthernet0/1/0(trunk) to get the following topology:
Host1(10.10.10.1)<-Vlan10->Gi0/0/1[Cat8200]Gig0/1/0(trunk)<-Vlan10->[intermediate switch]<-->Host2(10.1010.2)
interface GigabitEthernet0/1/0
switchport mode trunk
end
Various configuration of gig 0/0/1 don't work, sort of
interface GigabitEthernet0/0/1
no ip address
negotiation auto
service instance 10 ethernet
encapsulation dot1q 10
bridge-domain 10
Is switching between built-in Ethernet WAN ports and NIM-ES2-4 switch ports possible?
Thank you in advance!
8 Replies 8
but that not full config
you need
bridge 1 protocol ieee
bridge 1 route ip
to make router work as bridge.
add these command and check again
kgera
Thank you for reply!
Should it be vlan-bridge?
bridge 1 protocol ?
ast IBM protocol
dec DEC protocol
ibm IBM protocol
vlan-bridge vlan-bridge protocol
Configuring Transparent Bridging - Cisco
dec DEC protocol <<- I use this protocol in lab and success ping
but I must mention here something, in link I share there is note that mix ieee and dec protocol can lead to un predictable result.
so please read Link I share and then decide to config protocol dec.
thanks
MHM Cisco World,
Could you also please show at least  e0/0, e0/1 configuration?
Have you made a specific configuration for BDI and Vlan interfaces?
Seeing the full test configuration would be great!
Sorry, I meant e0/0, e 1/1, but the full configuration would be really useful
Thank you!
balaji.bandi
basically you can bridge domain using BVI as below example :
https://www.cisco.com/c/en/us/support/docs/lan-switching/integrated-routing-bridging-irb/200650-Understanding-Bridge-Virtual-Interface.html
I have never used 8200 - as per the documentation looks it does not support it.
check the feature navigator based on the IOS code running (show version)
https://cfnng.cisco.com/
Another side if the Ethernet module is available why not use all in and out connections with the Ethernet switch module (GigabitEthernet0/1/0-3)? what is the challenge here ? (why you need to use only L3 ports ?
BB
kgera
Hello balaji.bandi,
Yes, I read that artice and looks like C8200(IOS XE) does not support it, that's why I tried service instance and BDI
The challenge - Host1 provides the fiber connection, we can use SFP in Gig0/0/1. Switch ports are 1000BaseTX
For now, i can only think to get a Fiber to an ethernet adaptor to fix the solution you looking for. (if that device has limitation)
BB
