Cisco C9200L Firmware installation error
itsu
Hi Folks,
I have been having this issue/ error message when I try to upgrade firmware on my C9200L Cisco switch from 17.9.4 to 17.9.5.
Anyone with similar issue willing to help?
Below is the error message:
HO-IE-SW-STACK#$ file flash:cat9k_lite_iosxe.17.10.01.SPA.bin activate commit
*Jul 27 00:28:44.274: %INSTALL-5-INSTALL_START_INFO: Switch 1 R0/0: install_mgr: Started install add_activate_commit flash:cat9k_lite_iosxe.17.10.01.SPA.bin
*Jul 27 00:28:44.314: %INSTALL-3-OPERATION_ERROR_MESSAGE: Switch 1 R0/0: install_mgr: Failed to install add_activate_commit package flash:/cat9k_lite_iosxe.17.10.01.SPA.bin, Error:install_add_activate_commit: START Sat Jul 27 00:28:44 UTC 2024
install_add: Adding IMG
/mnt/sd3/user/cat9k_lite_iosxe.17.10.01.SPA.bin is not valid file or cannot be handled by install CLI.
[1] Switch 1 FAILED: Invalid installation package. Name cat9k_lite_iosxe.17.10.01.SPA.bin does not match with cat9k_lite_iosxe.17.10.01.SPA.bin.
FAILED: add_activate_commit /mnt/sd3/user/cat9k_lite_iosxe.17.10.01.SPA.bin Sat Jul 27 00:28:44 UTC 2024
shambhu.kumar
As you mentioned, you are upgrading C9200L Cisco switch from 17.9.4 to 17.9.5. But in error message it shows, you are installing cat9k_lite_iosxe.17.10.01.SPA.bin.
"Invalid installation package. Name cat9k_lite_iosxe.17.10.01.SPA.bin does not match with cat9k_lite_iosxe.17.10.01.SPA.bin."
Kindly check bootflash using "dir " what file is installed.
Please remove  inactive packages  using "install remove inactive" and upload the recommended  IOS-XE with correct md5 hash. configure "boot system bootflash:packages.conf" and install it again.
Leo Laohoo
In layman's term, this error message translates to "file (cat9k_lite_iosxe.17.10.01.SPA.bin) not found in the flash:"
M02@rt37
Hello @itsu
Please follow this
https://blog.noblinkyblinky.com/2019/07/27/upgrading-ios-xe-on-catalyst-9000-series-switch-stack/
Best regards
