Cisco C9300-48T Firmware upgrade from 16.9.3 to 17.9.4 IOSXE
amalmichaelvj
Hello Team,
Anyone please assist to complete Cisco 9300-48T firmware upgrade from IOSXE 16.9.3 to 17.9.4.
Please share upgrade Path ?
Also Upgrade Document or steps?
Thank u .. Please assist
2 Accepted Solutions
M02@rt37
Hello @amalmichaelvj,
Go straight! Direct upgrade is supported.
Check Release Notes for the intended version you want to install, items like that are usually explained and or elaborated at (look for items concerning installation notes and related).
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-9/release_notes/ol-17-9-9300.html
https://blog.noblinkyblinky.com/2019/07/27/upgrading-ios-xe-on-catalyst-9000-series-switch-stack/
Best regards
Leo Laohoo
1.  Direct upgrade to 17.9.4a is supported.
2.  Consider upgrading to 17.9.4a due to Multiple Vulnerabilities in Cisco IOS XE Software Web UI Feature
3.  Please refer to attached file for reference.
M02@rt37
Best regards
Leo Laohoo
