Cisco C9300 switch
ShivaniDutt0876
Does c9300 supports below mentioned features. If yes, what is the reference document for the same
Switch model  : C9300-24T
s/w Lic             : Network Advantage installed
to Show case  : 1.  MPLS VPLS feature
  1.  How to run L2VC with Huawei.
  2. How many VSI/L2VC support in Cisco.
  3. How to configure redundancy(VSI) in Cisco
pigallo
Hello, please see answers inline:
Yes it is supported. Check the reference below for more details:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Licensing
Supported as well, please check the configuratioin guide below:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/mpls/b_169_mpls_9300_cg/configuring_virtual___private_lan_service__vpls__and_vpls_bgp_based_autodiscovery.html
Below there are VPLS scale parameters as reported from Cisco website in comparison with other switch models:
Scale Numbers
Table 1. VPLS Scale
Platform
Scale numbers as per SDM
3650
32 VFI, 32 VLAN, 8 neighbour per VFI, 256 VC/PWs
3850
9300
128VFI, 128 VLAN, 32 neighbour per VFI, 1024 VC/PWs
9500
128VFI, 128 VLAN, 32 neighbour per VFI, 4096 VC/PWs
Kind regards
