Cisco C9300X-48HX Power supply compatibility
jdenzer
Does anybody know if the 715 Watt power supplies will work on a C9300X-48HX switch?
The standard power supply is the 1100 watt version, and it sticks out the back of the switch far enough that it may not fit in the cabinet I plan to put it in. It appears that the 715 watt power supply is around 1.5" "shorter" and that might be enough. It is going to be in a stack with a C9300-48U switch that is populated with 1100 water power supplies, so there should be plenty of available power for the HX thru the stack.
Ruben Cocheno
@jdenzer
From the datasheet seems to be supported, but double check just in case
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
Models
Primary Power Supply
Default or Upgrade
Available PoE
With 350W Secondary PS
With 715W secondary PS
With 1100W Secondary PS
With 1900W Secondary PS
C9300X-48HX
PWR-C1-1900WAC-P
Upgrade
1390W
1740W
2105W
2490W
3290W
PWR-C1-1100WAC-P
Default
590W
940W
1305W
1690W
2490W
PWR-C1-715WAC-P
Default
No POE
No POE
No POE
No POE
No POE
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
jdenzer
Thank you. I was looking at that same link, and it looks like the 715 watt power supply is for the C9300X-48TX switch.
