Cisco C9300X-48TX - network module port numbering
AigarsK
Hi All,
I just received two new C9300X-48TX which have optional network module C9300X-NM-8Y installed.
I just cannot make sense of the port numbering and would like someone to explain me this.
Switch has 48 Multigigabit (10G/5G/2.5G/1G/100M) ports.
C9300X-NM-8Y has 8x SFP+ (25G/10G/1G) ports.
When I am listing ports that are in config I see following:
Te1/0/47
Te1/0/48
Te1/1/1
Te1/1/2
Te1/1/3
Te1/1/4
Te1/1/5
Te1/1/6
Te1/1/7
Te1/1/8
TwentyFiveGigE1/1/1
TwentyFiveGigE1/1/2
TwentyFiveGigE1/1/3
TwentyFiveGigE1/1/4
TwentyFiveGigE1/1/5
TwentyFiveGigE1/1/6
TwentyFiveGigE1/1/7
TwentyFiveGigE1/1/8
TwentyFiveGigE1/1/9
TwentyFiveGigE1/1/10
TwentyFiveGigE1/1/11
TwentyFiveGigE1/1/12
TwentyFiveGigE1/1/13
TwentyFiveGigE1/1/14
TwentyFiveGigE1/1/15
TwentyFiveGigE1/1/16
HundredGigE1/1/1
HundredGigE1/1/2
HundredGigE1/1/3
HundredGigE1/1/4
When I connected the uplink to this switch, and plugged in Port 1 on C9300X-NM-8Y with 10Gbps SFP, it reported that TwentyFiveGigE1/1/1 is UP and not the expected "Te1/1/1"
Ok, sort of fine as I have seen that port always defaults to the one that technically is the highest speed interface is able to support.
But things that bug me are as followed:
• Why bother with listing Te1/1/1 to Te1/1/8 if a network module is not installed, same applies for the ports HundredGigE1/1/1 to HundredGigE1/1/4?
• Why is switch reporting ports TwentyFiveGigE1/1/9 to TwentyFiveGigE1/1/16 as available when C9300X-NM-8Y only has 8 ports?
Can someone please help me understand this?
Mark Elsen
  - Some switch models will 'provision' ports or port numbers anyway taking into account whatever module could be installed,
     Of course for a certain SFP or other connection , speed and active connection ,
     the correct port (as indicated with the speed) should be shown,
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks, so the reason there are 16x 25Gbps interfaces is to do with fanout cables that can be used on 100Gbps ports?
 - I think so ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
