Cisco C9500-24Y4C-A - Error: Licensing infrastructure is NOT initializ
marzi
Hi all
I've two C9500-24Y4C-A in stackwise-virtual fashion.
The IOS is Bengaluru 17.06.04.
Every command input I see the follow error message :
Error: Licensing infrastructure is NOT initialized.
How I can solve it ?
Fabrizio
6 Replies 6
marce1000
 - Check output of show license all
 M.
The show license all is not available in the command set
lacp Port channel information
ldap Shows LDAP information
line TTY line information
lisp Locator/ID Separation Protocol
lldp LLDP information
llp NHRP multicast map for link layer protocols
  - Is the device in ROMMON mode (and or else post the boot process) , (?)
 M.
Hi marce1000
No, the device is not in rommon mode, it is working properly,
We have configured vlan, interface vlan, routing protocol and so on, the only thing that is not correct is that message.
Thanks marce1000
   - Can you login normally and go to enable mode and get a normal (hostname based)  prompt  ?
                        If so issue the command show ?
 M.
Hi marce1000
We have fix the problem.
Inserting the follows command in the device and then reload it the error has been disappeared:
switch#license right-to-use activate addon dna-advantage subscription acceptEULA
Anyway, it seems was an activate license problem.
The command is what I’ve written above, but we have played with the cli before having that result, and I've not all the steps.
So, it is necessary a little working on it
