nexus 7000 - see if 25 or 40gig sfp+ modules supported
robertkwild
hi all,
i have nexus 7000 and i just want to check if 25 or 40gig sfp+ modules are supported on them
thanks,
rob
Reza Sharifi
Can you provide the part number for the module in the switch?
renan.abreu
You can use this link to check compatibility.
https://tmgmatrix.cisco.com/
