12-11-2019 07:13 AM
Hi All,
Does the high performance Cisco 9500 switches (C9500-48Y4C) support SVL?
Cisco IOS XE Fuji 16.9.x
Unsupported Features—Cisco Catalyst 9500 Series Switches - High Performance
Cisco Application Visibility and Control (AVC)
High Availability—Cisco Stackwise Virtual, Stateful Switchover (SSO), In Service Software Upgrade (ISSU), Nonstop Forwarding (NSF) (Enhanced Interior Gateway Routing Protocol (EIGRP) NSF and Open Shortest Path First (OSPF) NSF, NSF support for IPv6, NSF Awareness (BGP, EIGRP, OSPF))
MPLS Label Distribution Protocol (MPLS LDP) VRF-Aware Static Labels
Next Generation Network-Based Application Recognition (NBAR) and Next Generation NBAR (NBAR2)
QoS Options on GRE Tunnel Interfaces
Thanks in advance for any replies.
12-11-2019 08:37 AM
Yes, Stakwise virtual is supported on the 9500 series. see link
12-11-2019 09:27 AM
Hi Reza,
The link to the doc tells me how to configure SVL, my question was are the 9500 high performance switches able to support SVL.
I only ask as because the release notes say not supported.
Cheers,
12-11-2019 10:49 AM
Yes, they do as long as you are running 16.6.x or later. SVL stand for StackWise Virtual link, which is usually 2 10 Gig or 2 40 Gig links between the 2 switchers when building a StackWise Virtual system. see figure 3 in the link I posted.
The two-node solution of Cisco StackWise Virtual is normally deployed at the aggregation layer. Two switches are connected over a StackWise Virtual link (SVL).
12-18-2019 05:28 AM
Hi Reza,
As I suspected! Code version 16.9.4 and below does not support the SVL feature.
TAC engineer recommended 16.12.2 as a minimum due to the switches being the high performance models utilising different ASIC's.
Trying this now to ascertain if this actually works.
Not sure where you got your info from? Thanks anyway for the reply.
Jay
