Cisco Catalyst 2924 XL Fiber Connection
Winston87
Hello all,
I am one of the IT guys for my unit and have never once worked with fiber optical connections. We had a long stretch that needed to be ran with fiber in order to get them connected so we did but have had no success. We are using (2) Cisco Catalyst 2924 XL Series switches along with working media converters and patch fibers at each end.
I don't know much about configuring switches and spent a good amount of time reading the Guide for that series with no luck on figuring it out. I have confirmed in dir flash that it is a blank config. Is there something in particular I need to setup before the switches can pass traffic?
6 Replies 6
krishnakumarr
hi
can you provide me show version output
regards
krishna
Of course! Here is the show version output.
Switch#show version
IOS (tm) C2900XL Software (C2900XL-HS-M), Version 11.2(8)SA5, RELEASE SOFTWARE (
fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 23-Mar-99 11:44 by rheaton
Image text-base: 0x00003000, data-base: 0x001FAEF8
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 2 hours, 49 minutes
System restarted by power-on
System image file is "flash:c2900XL-hs-mz-112.8-SA5.bin", booted via
cisco WS-C2924M-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byt
es of memory.
Processor board ID 0x10, with hardware revision 0x03
Last reset from power-on
Processor is running Enterprise Edition Software
25 Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: **********
Motherboard assembly number: 73-3425-08
Power supply part number: 34-0920-01
Motherboard serial number: *********
Power supply serial number: **********
Model revision number: A0
Model number: WS-C2924M-XL-EN
System serial number: **********
Configuration register is 0xF
lusandi
Can you provide us the:
Show run of those ports?
And here is the blank and lonely looking configuration D:
Switch#show run
Building configuration...
Current configuration:
version 11.2
no service pad
no service udp-small-servers
no service tcp-small-servers
hostname Switch
interface VLAN1
no ip route-cache
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet1/1
interface FastEthernet1/2
line con 0
  stopbits 1
line vty 0 4
login
end
I hope this information will help.
This procedure assumes that the candidate switch has connectivity to the command switch through the same VLAN and is in the same management VLAN. For more information, see the "CLI Procedure for Assigning Static-Access Ports to a VLAN" section, "CLI Procedure for Assigning Ports for Multi-VLAN Membership" section, and "CLI Procedure for Configuring the Management VLAN Interface through a Console Connection" section.
Step 1 Enter global configuration mode.
configure terminal
Step 2 Enable the command switch and name the cluster (up to 31 characters).
cluster enable name
Step 3 Return to privileged EXEC mode.
end
Step 4 Display a list of candidates.
show cluster candidates
Step 5 Display a list of current cluster members.
show cluster members
Step 6 Enter global configuration mode.
configure terminal
Step 7 Add candidates to the cluster.
Assign a unique number from 1 to 15 for n. Do not use any switch number (SN) that appears in the show cluster members display. Enter the candidate switch MAC address, which can be obtained from the show cluster candidates display.
cluster member n mac-address hw-addr password password
Step 8 Return to privileged EXEC mode.
end
Step 9 Display the status of the cluster.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_xp/swcfg/kiclust.html
If there is something else I can do for you please let me know,
Thanks.
Ganesh Hariharan
Hi Josh,
For fiber, make sure you have the correct cable for the distances       involved and the type of fiber ports that are used. The two options are       singlemode fiber (SMF) or multimode fiber (MMF). Make sure the ports on the       devices that are connected together are both SMF, or both are MMF ports.
For fiber connections, make sure the transmit lead of one port is           connected to the receive lead of the other port. Connections for           transmit-to-transmit and receive-to-receive do not work.
Command is same to enable the fiber interface in cisco switch as if like ethernet port.
Hope that helps out  your query !!
Ganesh.H
