Cisco Catalyst 2960-48TC-L Switch webui login
dualchart
Good Evening all
I have just updated my switch to the latest version and prior to the update i had no login to access the webUI and or the Network Assistant and now its asking me to login to the management UI
and i cannot remember hte default username and password to login to the UI
any help would be greatful
Kind Regards
Sandeep Choudhary
As per my knowledge you have run the password recovery process:
Here is the process:
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
Unplug the power cable.
Power the switch and bring it to the
switch:
prompt:
For 2900XL, 3500XL, 2940, 2950, 2960, 2970, 3550, 3560, and 3750 series switches, do this:
Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch.
2960, 2970Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
3560, 3750Release the Mode button after approximately 15 seconds when the SYST LED turns solid green. When you release the Mode button, the SYST LED blinks green.
The system has been interrupted prior to initializing the flash file system to finishloading the operating system software:
flash_initload_helperbootswitch:
Issue the
flash_init
command.
switch: flash_init Initializing Flash... flashfs[0]: 143 files, 4 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 3612672 flashfs[0]: Bytes used: 2729472 flashfs[0]: Bytes available: 883200 flashfs[0]: flashfs fsck took 86 seconds ....done Initializing Flash. Boot Sector Filesystem (bs:) installed, fsid: 3 Parameter Block Filesystem (pb:) installed, fsid: 4 switch: !--- This output is from a 2900XL switch. Output from !--- other switches will vary slightly.
Issue the  load_helper command.
switch: load_helper switch:
Issue the dir flash: command.Note: Make sure to type a colon ":" after the dir flash.The switch file system is displayed:
switch: dir flash: Directory of flash:/ 2    -rwx  1803357                  c3500xl-c3h2s-mz.120-5.WC7.bin !--- This is the current version of software. 4    -rwx  1131                     config.text !--- This is the configuration file. 5    -rwx  109                      info 6    -rwx  389                      env_vars 7    drwx  640                      html 18   -rwx  109                      info.ver 403968 bytes available (3208704 bytes used) switch: !--- This output is from a 3500XL switch. Output from !--- other switches will vary slightly.
Type  rename flash:config.text flash:config.old to rename the configuration file.
switch: rename flash:config.text flash:config.old switch: !--- The config.text file contains the password !--- definition.
Issue the boot command to boot the system.
switch: boot Loading "flash:c3500xl-c3h2s-mz.120-5.WC7.bin"...############################### ################################################################################ ###################################################################### File "flash:c3500xl-c3h2s-mz.120-5.WC7.bin" uncompressed and installed, entry po int: 0x3000 executing... !--- Output suppressed. !--- This output is from a 3500XL switch. Output from other switches !--- will vary slightly.
Enter "n" at the prompt to abort the initial configuration dialog.
--- System Configuration Dialog --- At any point you may enter a question mark '?' for help. Use ctrl-c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !--- Type "n" for no. Press RETURN to get started. !--- Press Return or Enter. Switch> !--- The Switch> prompt is displayed.
At the switch prompt, type en to enter enable mode.
Switch>en Switch#
For password recovery
Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
Switch#rename flash:config.old flash:config.text Destination filename [config.text] !--- Press Return or Enter. Switch#
Copy the configuration file into memory.
Switch#copy flash:config.text system:running-config Destination filename [running-config]? !--- Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1#
The configuration file is now reloaded.
Overwrite  the current passwords that you do not know. Choose a strong password  with at least one capital letter, one number, and one special character.
Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords.
Sw1# conf t !--- To overwrite existing secret password Sw1(config)#enable secret  !--- To overwrite existing enable password Sw1(config)#enable password  !--- To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config-line)#password  Sw1(config-line)#login !--- To overwrite existing console password Sw1(config-line)#line con 0 Sw1(config-line)#password
Write the running configuration to the configuration file with the write memory command.
Sw1#write memory Building configuration... [OK] Sw1#
For Factory reset: dont give below command for factory reset
do copy running config to flash,
Switch#copy running-config flash:
[OK]
Switch#copy running-config startup-config
Destination filename [startup-config]?
[OK]
Go through the below link for more info
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Hope it helps.
James Neilson
The default for Cisco devices is usually cisco/cisco
