09-01-2019 05:49 AM
Hello Guys does any one have idea if 2960x 48 port with 370w stictly support 24poe ports for up to 15W or it can suport mor device if it is lowe that 15W.
waht is the maximum poe ports that can be supported if i will connect AIR-AP1815W-E-K9 with 8.5W power draw? is it still 24 port or it is load balancing based fro 370W max power.
09-01-2019 08:38 AM
Depends on exact model of the switch. some model support 740W also.
if you have 370W PSU, it calculated as per document 12 port- 30W and 24port - 15.4W.
you can connect more devices as long as you have enough PoE power. only issue you see while starting the device some device more power then they stable.
09-02-2019 12:22 AM
