Cisco Catalyst 2960 X does not permit traffic
rolandoravelo
I have a Cisco Catalyst 2960-X 48 ports, connected to a 6 Cisco Stack by Ethernet Port.
(This switch was part of the Stack, ad retired from it due a bad stack module)
The stack have the IP 172.16.0.10
The "problematic" switch have the IP 172.16.0.12
It's accessible from the LAN and can be managed via SSH.
No one device connected to any Ethernet port can reach the LAN.
I had reset the switch, after that, copied running-config from one of the stack members. Still the issue.
Also I realize the System Led is steady Amber.
Appreciate any idea.
Thank's
No traffic on all interfaces right?
This happened after a software update right?
You may have a counterfeit switch that was broken during the update procedure.
Check for this during the boot:
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Failed
If it's failed it's probably counterfeit and you may have something like "
%ILET-1-AUTHENTICATION_FAIL: This Switch may not have been manufactured by Cisco or with Cisco's authorization" on "sh logging".
11 Replies 11
Francesco Molino
If you can access the switch over ssh, can you share the following outputs and put them into a text file please:
- sh ip int brie
- sh vlan
- sh run
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Attached the 3 ouputs.
The switch is the AHE-SW-MASTER-6
Interface GigabitEthernet6/0/5 is connected to a Cisco Stack
On the GigabitEthernet6/0/15 there are an Avaya IP phone.
Is your avaya phone working on vlan 1?
This is the only vlan you have. If avaya are in another vlan then you should create it on this switch and make the interface 6/0/5 as a trunk with your upstream stack.
I would recommend to wr erase the switch and start with a fesh config just to have a cleaner config and not using interfaces named 6/0/x for a standalone switch.
Francesco
balaji.bandi
adding to other post, since you mentioned stack member
can you also post
show switch
show version
what is the user VLAN ?
BB
AHE-SW1-MASTER-6#show switch
Switch/Stack Mac Address : 2c0b.e966.8880
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 0 Provisioned
2 Member 0000.0000.0000 0 0 Provisioned
3 Member 0000.0000.0000 0 0 Provisioned
4 Member 0000.0000.0000 0 0 Provisioned
5 Member 0000.0000.0000 0 0 Provisioned
*6 Master 2c0b.e966.8880 1 4 Ready
AHE-SW1-MASTER-6#sh version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E0a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 12-Apr-19 04:09 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(6r)E, RELEASE SOFTWARE (fc1)
AHE-SW1-MASTER-6 uptime is 18 hours, 28 minutes
System restarted at 22:13:05 UTC Thu Jan 16 2020
System image file is "flash:/c2960x-universalk9-mz.152-7.E0a/c2960x-universalk9-mz.152-7.E0a.bin"
Last reload reason: Reload command
cisco WS-C2960X-48LPD-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FOC1942S0AB
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
300 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 2C:0B:E9:66:88:80
Motherboard assembly number : 73-14187-04
Power supply part number : 341-0527-01
Motherboard serial number : FOC1931P74W
Power supply serial number : DCB1932R46G
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C2960X-48LPD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC1935W35G
System serial number : FOC1942S0AB
Top Assembly Part Number : 800-41462-02
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : CMMLK00ARC
Daughterboard revision number : A0
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 6 54 WS-C2960X-48LPD-L 15.2(7)E0a C2960X-UNIVERSALK9-M
Configuration register is 0xF
As per the information you have a stack of 6 switch's  in the stack ? Please confirm
Looks like your configuration becomes default here.
BB
This switch was part of an stack.
Since FlexStack module failed, we retired it from the stack.
Now is STANDALONE.
Somebody performed a factory default reset on it, after that, I putted the running config from other switch.
I've tried in so many ways, but no traffic pass through.
Thank's
if this is a standalone switch.
you need to make it as default the switch - Write erase the config
do basic config example :
1. where this switch connecting to Uplink - port config
2. if all should be VLAN 1 you not required to config anything all belong to by default VLAN 1
3. do your basic VLAN interface config for the management.
4. what VLAN your Phone / Data port should be VLAN 1 ? or any other VLAN which was working. ( or can you provide other switch was working the environment. - to look and suggest you.).
BB
Thank you!  This is exactly what was happening. After contact to Cisco and provide them the serial number, they informed that I have a counterfeit device. Bad game of my vendor, putted on black list
Zachary Ballard
I would first verify that the trunk is forming between the two switches. Then I would move to the IP phone and make sure that it is getting an IP address.
