02-23-2022 12:05 AM
I have a strange question, to manage my 2960 catalyst I use the CP express web interface which is not very good,
Contrary to the Cisco business switch web interface that I find more pleasant to use.
My question is to know if it is possible to use the web interface Cisco business switch instead of the CP express on my Catalyst?
Thanks a lot.
Solved! Go to Solution.
02-23-2022 12:51 AM
- No , that is not possible,
M.
02-23-2022 02:12 AM
as per i know they are different models and different purpose, they can use same as you use for other small business switches,
yes agreed cisco should have 1 GUI which can cater all device in pane of glass (not to Pain...)
02-23-2022 12:51 AM
M.
02-23-2022 02:28 AM
Hello marce1000
Ok, thank you for your answer.
Have a great day (or evening, depending on where you are located on the globe)!
02-23-2022 02:12 AM
02-23-2022 02:30 AM
Hello balaji.bandi,
Thanks you for your answer,
Yes, because the CP Express web interface is a horror xD
