Cisco Catalyst 3500 XL Upgrade
daedae7878
I am trying to find out what the most upto date IOS I can put in my Cisco Catalyst 3500 XL switch, and I'm not sure if this the newest software. I have a lab setup at my house to study for the CCNP certs and this IOS doesn't have all the commands I need, well it might but all depracated commands.  Thank You in advance for your help
Switch#show version
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)XW, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 14-Dec-00 14:26 by devgoyal
Image text-base: 0x00003000, data-base: 0x00329DF8
ROM: Bootstrap program is C3500XL boot loader
Switch uptime is 32 minutes
System returned to ROM by reload
System image file is "flash:c3500XL-c3h2s-mz-120.5-XW"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes
of memory.
Processor board ID FAB0524M2FK, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Motherboard assembly number:
Power supply part number: 3
Motherboard serial number:
Power supply serial number:
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAB0524M2FK
Configuration register is 0xF
Latchum Naidu
Below are the latest versions.
c3500xl-c3h2s-tar.120-5.WC17.tar
c3500xl-c3h2s-mz.120-5.WC17.bin
Please rate the helpfull posts.
Naidu.
5 Replies 5
Latchum Naidu
Naidu.
Leo Laohoo
The latest-and-greatest IOS for the 3500 is the WC17.
daedae7878
Is there any IOS's for the Cisco Catalyst 3500 xl that support the following protocols
RSTP
PVST
PaGP
MST
  your best bet is to put on the last version they made for that switch and see if they are available . That switch has been out of production probably 10 years .
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc17/ol256213.html#wp39017
Please use the cisco feature navigator tool for complete information that you required.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp?calling_app=config
And I saw in one doc that c3500xl-c3h2s-mz.120-5.WC17.bin is not supporting some of the features like CEF and PApg
Naidu.
