Cisco Catalyst 3550 L3 switch
jgutierrezwfg
I'd like to know if it's possible to connect a fiber optic cable into the 3550 series L3 switch?
I'm assuming via SFP?
Thanks in advance
2 Accepted Solutions
Reza Sharifi
Can you provide the exact part number of the switch?
For the 3550 series, you usually use GIBC and not SFP for fiber connectivity.
See page 10 in this link:
https://www.cisco.com/c/dam/global/ko_kr/products/pc/switches/3550/preso-c3550-public.pdf
Seb Rupik
Hi there,
The old cat3550's used GBICs not SFPs, but yes, with the correct optics you can connect a fibre cable to it.
cheers,
Seb.
5 Replies 5
Reza Sharifi
The SN I got is CAT0812N4B8
And you're right, I realized that afterwards. Not sure where I can find a reliable GBIC for single mode fiber nowadays though. Seems most manufactures don't make them anymore.
Seb Rupik
Hi there,
cheers,
Seb.
Thank you for your response. I'm going to start searching for a GBIC for singlemode fiber
GBIC is very old, BUT You can most likely find then on Amazon or eBay for a very low price.
