Cisco Catalyst 3550
nelsonm
I am upgrading 6 Cisco Catalyst 3550 switch from 12.1.9 code to 12.2.46 SE6 this weekend. I want to copy of the old code. I've tried the standard copy flash:name tftp and archive upload-sw but they both error stating its a directory.
%Error opening flash:c3550-i9q3l2-mz.121-9.EA1c (Is a directory)
Any input on the best way to do this would be greatly appreciated.
Mark,
Have you got ".tar"? Try me.
Switch#archive upload-sw tftp://A.B.C.D/c3550-i9q3l2-mz.121-9.EA1c.tar
HTH,
Toshi
5 Replies 5
Jerry Ye
Hi Mark,
You boot up image is stored inside the directory c3550-i9q3l2-mz.121-9.EA1c. Use the following command to determine where is the image stored:
show boot
I suspect the image is in the following path
flash:/c3550-i9q3l2-mz.121-9.EA1c/c3550-i9q3l2-mz.121-9.EA1c
HTH,
jerry
Jerry,
Thanks for the input. I understand I can pull the c3550-i9q3l2-mz.121-9.EA1c.bin file from the directory. I want the whole directory. I assume it needs to be tar'd/zipped before pulling it off.
Thanks in advance!
Hi Mark,
Have you tried the following command
archive tar /create tftp://x.x.x.x/xyz.tar flash:/c3550-i9q3l2-mz.121-9.EA1c
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_9_ea1/configuration/guide/swiosfs.html#wp1030375
HTH,
jerry
Mark,
HTH,
Toshi
Thank you!
