Cisco Catalyst 3560 LINEPROTO-5-UPDOWN
Aquiles
we have a cisco router 2911 and 2 cisco catalyst 3650  the switch B is conected to siwtch A, and switch A is conected to Router, also we have a tp link 16 fastethernet, we have a survilliance system on our network, and we hve diferent kind of cameras ip,  but we have 2 cameras that only work if we conect to tp-link switch, if we connect to cisco switch they never get connnected, we tried  spanning-tree portfast,  and with this they link dont go down, but the never get ip address, if we move the camera to any port of the switch the same time happen.
what i am missing
Switch#sh int fa 0/31
FastEthernet0/31 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 001a.6dea.be23 (bia 001a.6dea.be23)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 8/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3458000 bits/sec, 524 packets/sec
5 minute output rate 54000 bits/sec, 87 packets/sec
1754906 packets input, 1436175903 bytes, 0 no buffer
Received 139 broadcasts (4 multicasts)
0 watchdog, 4 multicast, 3 pause input
259750 packets output, 20900446 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
we already change cable.
what is the brand/model of the IP cameras ? Where do they get their IP addresses from ? Since you have two switches, do both (3650) switches have the same VLANs (show vlan/show vtp)?
they are unitoptek i bought them at aliexpress, they are set static ip address, i have not setup the vpn so i have vpn1 as default, when i am at console this is what i got
*Mar 1 15:12:11.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to down
*Mar 1 15:12:13.232: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to up
*Mar 1 15:12:16.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to down
*Mar 1 15:12:18.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to up
*Mar 1 15:12:38.012: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to down
*Mar 1 15:12:39.010: %LINK-3-UPDOWN: Interface FastEthernet0/31, changed state to down
*Mar 1 15:12:41.024: %LINK-3-UPDOWN: Interface FastEthernet0/31, changed state to up
*Mar 1 15:12:42.030: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to up
*Mar 1 15:13:14.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to down
*Mar 1 15:13:16.835: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/31, changed state to up
*Mar 1 15:53:11.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
*Mar 1 15:53:12.677: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
*Mar 1 15:53:18.617: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
*Mar 1 15:53:22.324: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to up
*Mar 1 15:53:24.355: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
*Mar 1 15:53:25.353: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
*Mar 1 15:53:27.408: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
*Mar 1 15:53:28.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to up
