Cisco Catalyst 3750-X Switch default username and password
roopesh
Hi All,
I have Reset my cisco 3750 switch using MODE button present on front side of the switch and
1. after that I have assigned the ip using putty console and
2. I am able to open the web console using that ip,
3. but i am not able login to switch since it is asking for username and password which i dont have
Please help !!!
Mark Elsen
       >... but i am not able login to switch since it is asking for username and password which i dont have
 There isn't any , you have to go through setup (mode) on the console to define minimal parameters such as enable secret password
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
