bypass enable password
Psmurali89
Hi All,
Am configuring new routers with local user login (this will eventually move to Radius in future). The access works fine but not sure how to bypass the enable password for the privilege 15 user.
Below is the aaa config, I believe am missing something in this?
enable secret 5 xxxxxxx
username user1 privilege 15 password 7 xxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa session-id common
here there is chicken and egg issue
the privilege work in case of you not add enable password to your config
but here you add aaa auth enable using enable password
so solution, please try it in lab and see it effect before apply in real network
no enable secret 5 xxxxxxx
no aaa authentication enable default enable
Use the following command:
line vty 0 15
privilege level 15
