Cisco Catalyst 3750G StackWise Technology
jplenbrook
Level 2
Level 2
Hi everybody,
First of all, I am very excited to be able to join Cisco Support Community forum! Great stuff. I hope I can contribute as well in the very near future.
Now, we are looking into purchasing three WS-C3750G-48TS-S and stacking all of them together.
Now, as I am fresh to this technology I have some questions.
1. If you stack three switches with the StackWise cable, do you need to connect them with Ethernet Cable as well? In my understanding, connecting three switches with the StackWise cable configures them to act as a one physical device just like chassis based switches Catalyst 4500 or 6500.
Let's say we have multiple VLANs, do I need to configure VTP and trunks between them? Or would the StackWise cable just configure all of it as one switch so I don't need trunk between the switches? I know this may be a stupid question, but I am not too sure about that.
2. I also understand that there are multiple ways of connecting your switches together with the StackWise cable, however the most redundant connection would be so that the top switch connects with the bottom one, and the switches in between interconnect to the top and to the bottom with each other. Is that correct?
I have attached a screenshot from Cisco website, would this be the most efficient configuration?
Cisco Stack
3. What happens when the master switch (which has got connectivity to the router) goes offline? I understand that the new master election will happen based on priority or MAC, however new master switch would not have a link to the router and the outside. Is there any redundant configuration so let's say when master goes down, I can just unplug the cable and connect it to the new master? We use 1941/K9 as a default gateway and we do not have switch port module installed at the moment so there is only 1 LAN port available running multiple vLANs.
Thanks guys in advance and I look forward to hearing from you.
23 Replies 23
Thanks for claryfing everything. It makes sense.
If I decide to assign static switch priorities in the stack, do they have to be configured before stack is connected together or can I configure multiple switches while they are part of the stack? If so, how would you assign static priority for specific switch. In my understanding, as soon as you connect all the switches with stackwise, it becomes one logical switch therefore you don't have configuration for multiple physical switches, it comes as one big switch.
I know how to configure static priority, my question is just on how to configure priority for specific switch while stackwise is in effect?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You can configure switch priorities either before or after joining stack member.  However, with before, you'll need to configure the stack master.
For how, see: http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#pval
Thanks 🙂 I think I have exhausted this topic for now 🙂
Today we received our first delivery of three 3750G and our project will start shortly.
Hi everybody,
I have 3 switches connected as shown in my original post, however I get 4 switches in the stack for some reason, although all of them have the factory configuration.
Is it because switch 3 conencts to switch 1 and it thinks that this is another switch?
Here is my show commands output:
Switch#show switch
Switch/Stack Mac Address : 3cdf.1ec5.5480
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 3cdf.1ec5.5480     15     0       Ready
 2       Member e804.62a7.7880     14     0       Ready
 3       Member 081f.f395.f480     13     0       Ready
 5       Member 0000.0000.0000     0      0       Provisioned
Switch#show ip int br
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  administratively down down
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   unassigned      YES unset  down                  down
GigabitEthernet1/0/3   unassigned      YES unset  down                  down
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
GigabitEthernet1/0/5   unassigned      YES unset  down                  down
GigabitEthernet1/0/6   unassigned      YES unset  down                  down
GigabitEthernet1/0/7   unassigned      YES unset  down                  down
GigabitEthernet1/0/8   unassigned      YES unset  down                  down
GigabitEthernet1/0/9   unassigned      YES unset  down                  down
GigabitEthernet1/0/10  unassigned      YES unset  down                  down
GigabitEthernet1/0/11  unassigned      YES unset  down                  down
GigabitEthernet1/0/12  unassigned      YES unset  down                  down
GigabitEthernet1/0/13  unassigned      YES unset  down                  down
GigabitEthernet1/0/14  unassigned      YES unset  down                  down
GigabitEthernet1/0/15  unassigned      YES unset  down                  down
GigabitEthernet1/0/16  unassigned      YES unset  down                  down
GigabitEthernet1/0/17  unassigned      YES unset  down                  down
GigabitEthernet1/0/18  unassigned      YES unset  down                  down
GigabitEthernet1/0/19  unassigned      YES unset  down                  down
GigabitEthernet1/0/20  unassigned      YES unset  down                  down
GigabitEthernet1/0/21  unassigned      YES unset  down                  down
GigabitEthernet1/0/22  unassigned      YES unset  down                  down
GigabitEthernet1/0/23  unassigned      YES unset  down                  down
GigabitEthernet1/0/24  unassigned      YES unset  down                  down
GigabitEthernet1/0/25  unassigned      YES unset  down                  down
GigabitEthernet1/0/26  unassigned      YES unset  down                  down
GigabitEthernet1/0/27  unassigned      YES unset  down                  down
GigabitEthernet1/0/28  unassigned      YES unset  down                  down
GigabitEthernet1/0/29  unassigned      YES unset  down                  down
GigabitEthernet1/0/30  unassigned      YES unset  down                  down
GigabitEthernet1/0/31  unassigned      YES unset  down                  down
GigabitEthernet1/0/32  unassigned      YES unset  down                  down
GigabitEthernet1/0/33  unassigned      YES unset  down                  down
GigabitEthernet1/0/34  unassigned      YES unset  down                  down
GigabitEthernet1/0/35  unassigned      YES unset  down                  down
GigabitEthernet1/0/36  unassigned      YES unset  down                  down
GigabitEthernet1/0/37  unassigned      YES unset  down                  down
GigabitEthernet1/0/38  unassigned      YES unset  down                  down
GigabitEthernet1/0/39  unassigned      YES unset  down                  down
GigabitEthernet1/0/40  unassigned      YES unset  down                  down
GigabitEthernet1/0/41  unassigned      YES unset  down                  down
GigabitEthernet1/0/42  unassigned      YES unset  down                  down
GigabitEthernet1/0/43  unassigned      YES unset  down                  down
GigabitEthernet1/0/44  unassigned      YES unset  down                  down
GigabitEthernet1/0/45  unassigned      YES unset  down                  down
GigabitEthernet1/0/46  unassigned      YES unset  down                  down
GigabitEthernet1/0/47  unassigned      YES unset  down                  down
GigabitEthernet1/0/48  unassigned      YES unset  down                  down
GigabitEthernet1/0/49  unassigned      YES unset  down                  down
GigabitEthernet1/0/50  unassigned      YES unset  down                  down
GigabitEthernet1/0/51  unassigned      YES unset  down                  down
GigabitEthernet1/0/52  unassigned      YES unset  down                  down
GigabitEthernet2/0/1   unassigned      YES unset  down                  down
GigabitEthernet2/0/2   unassigned      YES unset  down                  down
GigabitEthernet2/0/3   unassigned      YES unset  down                  down
GigabitEthernet2/0/4   unassigned      YES unset  down                  down
GigabitEthernet2/0/5   unassigned      YES unset  down                  down
GigabitEthernet2/0/6   unassigned      YES unset  down                  down
GigabitEthernet2/0/7   unassigned      YES unset  down                  down
GigabitEthernet2/0/8   unassigned      YES unset  down                  down
GigabitEthernet2/0/9   unassigned      YES unset  down                  down
GigabitEthernet2/0/10  unassigned      YES unset  down                  down
GigabitEthernet2/0/11  unassigned      YES unset  down                  down
GigabitEthernet2/0/12  unassigned      YES unset  down                  down
GigabitEthernet2/0/13  unassigned      YES unset  down                  down
GigabitEthernet2/0/14  unassigned      YES unset  down                  down
GigabitEthernet2/0/15  unassigned      YES unset  down                  down
GigabitEthernet2/0/16  unassigned      YES unset  down                  down
GigabitEthernet2/0/17  unassigned      YES unset  down                  down
GigabitEthernet2/0/18  unassigned      YES unset  down                  down
GigabitEthernet2/0/19  unassigned      YES unset  down                  down
GigabitEthernet2/0/20  unassigned      YES unset  down                  down
GigabitEthernet2/0/21  unassigned      YES unset  down                  down
GigabitEthernet2/0/22  unassigned      YES unset  down                  down
GigabitEthernet2/0/23  unassigned      YES unset  down                  down
GigabitEthernet2/0/24  unassigned      YES unset  down                  down
GigabitEthernet2/0/25  unassigned      YES unset  down                  down
GigabitEthernet2/0/26  unassigned      YES unset  down                  down
GigabitEthernet2/0/27  unassigned      YES unset  down                  down
GigabitEthernet2/0/28  unassigned      YES unset  down                  down
GigabitEthernet2/0/29  unassigned      YES unset  down                  down
GigabitEthernet2/0/30  unassigned      YES unset  down                  down
GigabitEthernet2/0/31  unassigned      YES unset  down                  down
GigabitEthernet2/0/32  unassigned      YES unset  down                  down
GigabitEthernet2/0/33  unassigned      YES unset  down                  down
GigabitEthernet2/0/34  unassigned      YES unset  down                  down
GigabitEthernet2/0/35  unassigned      YES unset  down                  down
GigabitEthernet2/0/36  unassigned      YES unset  down                  down
GigabitEthernet2/0/37  unassigned      YES unset  down                  down
GigabitEthernet2/0/38  unassigned      YES unset  down                  down
GigabitEthernet2/0/39  unassigned      YES unset  down                  down
GigabitEthernet2/0/40  unassigned      YES unset  down                  down
GigabitEthernet2/0/41  unassigned      YES unset  down                  down
GigabitEthernet2/0/42  unassigned      YES unset  down                  down
GigabitEthernet2/0/43  unassigned      YES unset  down                  down
GigabitEthernet2/0/44  unassigned      YES unset  down                  down
GigabitEthernet2/0/45  unassigned      YES unset  down                  down
GigabitEthernet2/0/46  unassigned      YES unset  down                  down
GigabitEthernet2/0/47  unassigned      YES unset  down                  down
GigabitEthernet2/0/48  unassigned      YES unset  down                  down
GigabitEthernet2/0/49  unassigned      YES unset  down                  down
GigabitEthernet2/0/50  unassigned      YES unset  down                  down
GigabitEthernet2/0/51  unassigned      YES unset  down                  down
GigabitEthernet2/0/52  unassigned      YES unset  down                  down
GigabitEthernet3/0/1   unassigned      YES unset  down                  down
GigabitEthernet3/0/2   unassigned      YES unset  down                  down
GigabitEthernet3/0/3   unassigned      YES unset  down                  down
GigabitEthernet3/0/4   unassigned      YES unset  down                  down
GigabitEthernet3/0/5   unassigned      YES unset  down                  down
GigabitEthernet3/0/6   unassigned      YES unset  down                  down
GigabitEthernet3/0/7   unassigned      YES unset  down                  down
GigabitEthernet3/0/8   unassigned      YES unset  down                  down
GigabitEthernet3/0/9   unassigned      YES unset  down                  down
GigabitEthernet3/0/10  unassigned      YES unset  down                  down
GigabitEthernet3/0/11  unassigned      YES unset  down                  down
GigabitEthernet3/0/12  unassigned      YES unset  down                  down
GigabitEthernet3/0/13  unassigned      YES unset  down                  down
GigabitEthernet3/0/14  unassigned      YES unset  down                  down
GigabitEthernet3/0/15  unassigned      YES unset  down                  down
GigabitEthernet3/0/16  unassigned      YES unset  down                  down
GigabitEthernet3/0/17  unassigned      YES unset  down                  down
GigabitEthernet3/0/18  unassigned      YES unset  down                  down
GigabitEthernet3/0/19  unassigned      YES unset  down                  down
GigabitEthernet3/0/20  unassigned      YES unset  down                  down
GigabitEthernet3/0/21  unassigned      YES unset  down                  down
GigabitEthernet3/0/22  unassigned      YES unset  down                  down
GigabitEthernet3/0/23  unassigned      YES unset  down                  down
GigabitEthernet3/0/24  unassigned      YES unset  down                  down
GigabitEthernet3/0/25  unassigned      YES unset  down                  down
GigabitEthernet3/0/26  unassigned      YES unset  down                  down
GigabitEthernet3/0/27  unassigned      YES unset  down                  down
GigabitEthernet3/0/28  unassigned      YES unset  down                  down
GigabitEthernet3/0/29  unassigned      YES unset  down                  down
GigabitEthernet3/0/30  unassigned      YES unset  down                  down
GigabitEthernet3/0/31  unassigned      YES unset  down                  down
GigabitEthernet3/0/32  unassigned      YES unset  down                  down
GigabitEthernet3/0/33  unassigned      YES unset  down                  down
GigabitEthernet3/0/34  unassigned      YES unset  down                  down
GigabitEthernet3/0/35  unassigned      YES unset  down                  down
GigabitEthernet3/0/36  unassigned      YES unset  down                  down
GigabitEthernet3/0/37  unassigned      YES unset  down                  down
GigabitEthernet3/0/38  unassigned      YES unset  down                  down
GigabitEthernet3/0/39  unassigned      YES unset  down                  down
GigabitEthernet3/0/40  unassigned      YES unset  down                  down
GigabitEthernet3/0/41  unassigned      YES unset  down                  down
GigabitEthernet3/0/42  unassigned      YES unset  down                  down
GigabitEthernet3/0/43  unassigned      YES unset  down                  down
GigabitEthernet3/0/44  unassigned      YES unset  down                  down
GigabitEthernet3/0/45  unassigned      YES unset  down                  down
GigabitEthernet3/0/46  unassigned      YES unset  down                  down
GigabitEthernet3/0/47  unassigned      YES unset  down                  down
GigabitEthernet3/0/48  unassigned      YES unset  down                  down
GigabitEthernet3/0/49  unassigned      YES unset  down                  down
GigabitEthernet3/0/50  unassigned      YES unset  down                  down
GigabitEthernet3/0/51  unassigned      YES unset  down                  down
GigabitEthernet3/0/52  unassigned      YES unset  down                  down
GigabitEthernet5/0/1   unassigned      YES unset  down                  down
GigabitEthernet5/0/2   unassigned      YES unset  down                  down
GigabitEthernet5/0/3   unassigned      YES unset  down                  down
GigabitEthernet5/0/4   unassigned      YES unset  down                  down
GigabitEthernet5/0/5   unassigned      YES unset  down                  down
GigabitEthernet5/0/6   unassigned      YES unset  down                  down
GigabitEthernet5/0/7   unassigned      YES unset  down                  down
GigabitEthernet5/0/8   unassigned      YES unset  down                  down
GigabitEthernet5/0/9   unassigned      YES unset  down                  down
GigabitEthernet5/0/10  unassigned      YES unset  down                  down
GigabitEthernet5/0/11  unassigned      YES unset  down                  down
GigabitEthernet5/0/12  unassigned      YES unset  down                  down
GigabitEthernet5/0/13  unassigned      YES unset  down                  down
GigabitEthernet5/0/14  unassigned      YES unset  down                  down
GigabitEthernet5/0/15  unassigned      YES unset  down                  down
GigabitEthernet5/0/16  unassigned      YES unset  down                  down
GigabitEthernet5/0/17  unassigned      YES unset  down                  down
GigabitEthernet5/0/18  unassigned      YES unset  down                  down
GigabitEthernet5/0/19  unassigned      YES unset  down                  down
GigabitEthernet5/0/20  unassigned      YES unset  down                  down
GigabitEthernet5/0/21  unassigned      YES unset  down                  down
GigabitEthernet5/0/22  unassigned      YES unset  down                  down
GigabitEthernet5/0/23  unassigned      YES unset  down                  down
GigabitEthernet5/0/24  unassigned      YES unset  down                  down
GigabitEthernet5/0/25  unassigned      YES unset  down                  down
GigabitEthernet5/0/26  unassigned      YES unset  down                  down
GigabitEthernet5/0/27  unassigned      YES unset  down                  down
GigabitEthernet5/0/28  unassigned      YES unset  down                  down
GigabitEthernet5/0/29  unassigned      YES unset  down                  down
GigabitEthernet5/0/30  unassigned      YES unset  down                  down
GigabitEthernet5/0/31  unassigned      YES unset  down                  down
GigabitEthernet5/0/32  unassigned      YES unset  down                  down
GigabitEthernet5/0/33  unassigned      YES unset  down                  down
GigabitEthernet5/0/34  unassigned      YES unset  down                  down
GigabitEthernet5/0/35  unassigned      YES unset  down                  down
GigabitEthernet5/0/36  unassigned      YES unset  down                  down
GigabitEthernet5/0/37  unassigned      YES unset  down                  down
GigabitEthernet5/0/38  unassigned      YES unset  down                  down
GigabitEthernet5/0/39  unassigned      YES unset  down                  down
GigabitEthernet5/0/40  unassigned      YES unset  down                  down
GigabitEthernet5/0/41  unassigned      YES unset  down                  down
GigabitEthernet5/0/42  unassigned      YES unset  down                  down
GigabitEthernet5/0/43  unassigned      YES unset  down                  down
GigabitEthernet5/0/44  unassigned      YES unset  down                  down
GigabitEthernet5/0/45  unassigned      YES unset  down                  down
GigabitEthernet5/0/46  unassigned      YES unset  down                  down
GigabitEthernet5/0/47  unassigned      YES unset  down                  down
GigabitEthernet5/0/48  unassigned      YES unset  down                  down
GigabitEthernet5/0/49  unassigned      YES unset  down                  down
GigabitEthernet5/0/50  unassigned      YES unset  down                  down
GigabitEthernet5/0/51  unassigned      YES unset  down                  down
GigabitEthernet5/0/52  unassigned      YES unset  down                  down
Thanks.
- See more at: https://supportforums.cisco.com/discussion/12527056/cisco-catalyst-3750g-stackwise-technology#comment-10565231
Your 4th switch appears to be preprovisioned that's not physically present.
Ok, got it.
Removed switch 5, probably switch 5 was automatic id assigned when I first booted up the stack and then I think that I've changed 5 to 1 and that's why this has happened.
Please can someone delete this reply as it is not the latest one.
jplenbrook
Level 2
Level 2
Hi everybody,
Switch#show switch
                                           H/W   Current
Thanks.
