Cisco Catalyst 3850 SFP+ feature
Hi ALL.
I reed datasheet on WS-C3850 series switches and see in this document that 3850XS support 1/10G SFP+
WS-C3850-12XS
12 1/10G SFP+
What is 1/10G SFP+?
Really there is SFP+ with support of speed 1Gbit/s or this SW support SFP modules?
2 Accepted Solutions
Yes you can there backward compatible , obviously the type of sfp needs to be supported in the platform but once it is yes you can use a gb sfp in an sfp+ 10gb port
Joseph W. Doherty
I believe others have already answered, but a SFP+ port supports either gig or 10g, which is actually used, gig or 10g, depends on whether a gig or 10g transceiver is used in the port.
So on that switch you can have any combination of gig or 10g for its 12 ports.
9 Replies 9
Mark Malone
These are the new 10GB switches range but the ports are also backward compatabile to a 1GB , so standard as 10gb but can be 1gb too
Hi Mark.
Many thanks for you answer.
That is in 3850XS I can connect SFP to the same ports as SFP+?
Usually there are modules of SFPs for:
GigaEthernet only,
Gigaethernet and 10Giga
and 10 Giga only.
You should see what module has installed the device, you will see a small words like: G1 (Por 1 GigaEthernet) or G3 - TE 3 (Port 3 Giga or Ten) below the SFP modules. Now for the other 12 ports you need to verify if they support 10G or just 1Gb.
http://www.cisco.com/c/en/us/products/switches/catalyst-3850-series-switches/models-comparison.html
https://www.google.com.sv/search?q=cisco+3850+modules&rlz=1C1HIJA_enSV704SV704&espv=2&biw=1242&bih=602&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjImYKCr8TSAhWB0iYKHVSMAjQQ_AUIBigB#imgrc=-TsR9H9_eSLvkM:
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi.
I not have question for use additional NM-module for WS-C3800. This is clear.
I want to understand it is possible to use SFP and SFP + modules in one ports for WS-C3850-XS.
For example: I have WS-C3850-12XS and two modules SFP-10G-SR and GLC-LH-SM. I will be able to connect these two modules to any two built-in ports of this SW at the same time?
If your devices is WS-C3850-12X48U-S and we are based on the attached table, Multi Giga Ethernet ports, you can use SFP or SFP+  for 12 ports and optional until other 8 x 10 Ten Gig (SFP+)  if a module is installed.
WS-C3850-12X48U-S 36 UPOE 12 UPOE 1100 W, 800 W 4 x 1 GE
2 x 10 GE
4 x 10 GE
8 x 10 GE
2 x 40 GE
Yes
This link could be useful:
https://www.cnet.com/products/cisco-catalyst-3850-12xs-s-switch-12-ports-managed-rack-mountable/specs/
Julio E. Moisa
The following links could be useful, verify the SFP supported by model:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc462044413
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/installation/note/78_15160.html
Cisco SFP+ modules offer the following features and benefits.
   Industry’s smallest 10G form factor for greatest density per chassis
   Hot-swappable input/output device that plugs into an Ethernet SFP+ port of a Cisco switch (no need to power down if installing or replacing)
   Supports “pay-as-you-populate” model for investment protection and ease of technology migration
   Digital optical monitoring capability for strong diagnostic capabilities
   Optical interoperability with 10GBASE XENPAK, 10GBASE X2, and 10GBASE XFP interfaces on the same link
   Cisco quality identification (ID) feature enables a Cisco platform to identify whether the module is certified and tested by Cisco
Catalyst 3850 series
Network Device
Transceiver Model
Minimum Software Release Required
DOM Support
Software Release
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(with C3850-NM-8-10G NM)
GLC-T (10/100/1000)
GLC-LH-SM
GLC-LH-SMD
GLC-SX-MM
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-T
SFP-GE-Z
DWDM SFP
DWDM SFP (add.)
GLC-BX40-D-I
GLC-BX40-DA-I
GLC-BX40-U-I
GLC-BX80-D-I
GLC-BX80-U-I
XE 3.7.1
XE 3.7.1
WS-C3850-48XS-S
WS-C3850-48XS-E
WS-C3850-48XS-F-S
WS-C3850-48XS-F-E
WS-C3850-48XS
GLC-T (10/100/1000)
GLC-LH-SM
GLC-LH-SMD
GLC-SX-MM
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-T
SFP-GE-Z
DWDM SFP
DWDM SFP (add.)
GLC-BX40-D-I
GLC-BX40-DA-I
GLC-BX40-U-I
GLC-BX80-D-I
GLC-BX80-U-I
XE 3.7.2
XE 3.7.2
Hope it is useful
Joseph W. Doherty
