Cisco Catalyst 4500X VRF
Hello Team,
I need help leaking global routes to vrf and vfr routed to global in 4500x switch.
Routes are not showing up form global table inside vrf routing table,
I need to be able to import both ipv4 and ipv6 routes from global routing table.
vrf definition ill
rd 1000:1000
address-family ipv4
import map red
export map red
exit-address-family
address-family ipv6
import map red
export map red
exit-address-family
2 Accepted Solutions
export ipv6 unicast map xxx <<- use this for export
and use static  route for traffic from global to VRF
the import ipv6 is missing.
Thanks A Lot
MHM
I found a better solution,
I created additional vrf and add all global interface and routes to new vrf,
Its simpler to maintain this way,
vrf to vrf all commands work, vrf to global is pain to get everything working with ipv6 dual stack
I recommed to just creating new vrf for global and use it for route leaking.
10 Replies 10
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/216541-vrf-configuration-examples-on-ios-xe.html
import ipv4 unicast map GLOBAL-into-VRF
use above command
Thanks A Lot
MHM
Tried that command too, still not working.
did you add BGP ?
router bgp x
redistribute connected
address family IPv4 vrf Y
then add import ipv4 unicast... command
Thanks A Lot
MHM
Hi ,
I have found the issue,
what i was doing was i was using single route-map and matching both ipv4 and ipv6 prefixes, which somehow breaks import,
but if you use separate route-map for matching ipv4 and ipv6 separately it works.
Glad issue solved
have a nice day
Thanks A Lot
MHM
But The same is not working for ipv6 prefix, please help.
can I see the last config
Thanks A Lot
MHM
vrf definition ill
rd 1000:1000
address-family ipv4
import ipv4 unicast map red
export ipv4 unicast map blue
exit-address-family
address-family ipv6
import map redv6
export map bluev6
exit-address-family
There is no import ipv6 unicast map <===option
Thanks A Lot
MHM
