CISCO Catalyst 4506 count interface input/output rate always 0
philiptam
Dear Sir,
Our customer get the problem that the switch count the 5mins input/output rate of connected traffic interface always ZERO.
The problem only occur in the module 3,4 and 5 interface, module 2 has no problems.
May I ask are there any software bug will cause this issue????
Catayst 4506E
12.2(52)SG
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E
2    48  10/100/1000BaseT (RJ45)                WS-X4548-GB-RJ45
3    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E
4    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E
5    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E
GigabitEthernet2/3 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0024.1441.12d2 (bia 0024.1441.12d2)
  Description: *** HTTP Server-1 p3 ***
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is on, output flow-control is on
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 30w5d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 248348
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 45000 bits/sec, 14 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     656490115 packets output, 439577149306 bytes, 0 underruns
     0 lost carrier, 0 no carrier
GigabitEthernet3/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 68ef.bdfd.dbb9 (bia 68ef.bdfd.dbb9)
  Description: ** Automation DEV-2 **
  Auto-MDIX on (operational: on)
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
     12138884114 packets input, 18042976913749 bytes, 0 no buffer
     Received 128075 broadcasts (0 multicasts)
     16314804370 packets output, 2098191873853 bytes, 0 underruns
Million Thanks
Thanks and regards,
Philip
dominic.caron
Level 5
Level 5
Bug :CSCsz18634
Fixed in 12.2(54)SG
Brother, I just found the useful BugID and thank you very much.~Cheers~~~~
