Cisco Catalyst 500 and NTP
serotonin888
Hi All,
Does anyone know how to change\add a ntp server into the config on a catalyst 500 express switch?
It seems to be going to an internet NTP server by default.
Many Thanks
Andy
From: http://www.cisco.com/application/pdf/en/us/guest/products/ps6545/c2001/ccmigration_09186a0080539179.pdf
The switch clock is automatically synchronized with the
system clock on your network management station. You can manually set the
system clock settings if the switch should have different time settings.
I hope this helps.
Best regards.
Massimiliano.
purohit_810
Level 5
Level 5
Task Command
Step 1
Specify the IP address of the NTP server.
set ntp server ip_addr
Step 2
Enable NTP client mode.
set ntp client enable
Step 3
Verify the NTP configuration.
show ntp [noalias]
Dharmesh Purohit
