Cisco Catalyst 9000 Stackwise Virtual Running-Config
FirmanSanjaya
Community Member
Does anyone know if I've configured access list and vlan in the primary switch before I configured it with stackwise virtual configuration, Is it lost or still there when the switch is reload for stackwise synchronization process with the secondary switch ?
Thanks in advanced
pieterh
the process is similar to "adding a switch to a stack"
- the global configuration is used from the primary switch for centralized management
- the switchport configuration is kept for both switches, but interfaces on the secondary switch are renumbered
for full documentation see  Products - Cisco Catalyst 9000 Platform StackWise Virtual White Paper - Cisco
pieterh
