Cisco catalyst 9200 and 9300 Switch Flash Memory size shown is lower
Hello Dears,
The flash memory we're seeing on C9200-48T & C9300-48U switch is lower than expected which is nearly 10.7 Gb but the expected one is16Gb and please clarify why is that happening. below is the show outputs to see the flash memory size.
Cisco C9300-48U (X86) processor with 1331521K/6147K bytes of memory.
Processor board ID FOC2523LB00
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2 TwentyFive Gigabit Ethernet interfaces
2 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
cisco C9200-48T (ARM64) processor with 649172K/3071K bytes of memory.
Processor board ID JAE25170L1E
4 Ten Gigabit Ethernet interfaces
4060240K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
Please advise on the issue !
5 Replies 5
Reza Sharifi
Can you post the output of "show flash" and "dir"
Also, if you want to see a breakdown of all the files and how much space they take on the flash, issue the "sh file system" command.
Switch#show flash:
-#- --length-- ---------date/time--------- path
2 2097152 Dec 30 2021 11:06:53.0000000000 +00:00 nvram_config
3 2097152 Dec 30 2021 11:06:53.0000000000 +00:00 nvram_config_bkup
4 17392652 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-cc_srdriver.17.03.03.SPA.pkg
5 104428552 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-espbase.17.03.03.SPA.pkg
6 2262024 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-guestshell.17.03.03.SPA.pkg
7 5124 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-lni.17.03.03.SPA.pkg
8 595178500 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-rpbase.17.03.03.SPA.pkg
9 34792456 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-sipbase.17.03.03.SPA.pkg
10 57529348 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-sipspa.17.03.03.SPA.pkg
11 28738568 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-srdriver.17.03.03.SPA.pkg
12 14427140 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-webui.17.03.03.SPA.pkg
13 9220 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-wlc.17.03.03.SPA.pkg
14 6802 Jun 15 2021 18:46:14.0000000000 +00:00 packages.conf
15 47364227 Jun 15 2021 18:46:14.0000000000 +00:00 cat9k-rpboot.17.03.03.SPA.pkg
--More--   16 4096 Dec 30 2021 11:10:31.0000000000 +00:00 .installer
17 4096 Jun 15 2021 18:48:39.0000000000 +00:00 .installer/issu_crash
18 14 Dec 30 2021 11:06:14.0000000000 +00:00 .installer/watchlist
19 185 Dec 30 2021 11:05:24.0000000000 +00:00 bootloader_evt_handle.log
20 4096 Jun 15 2021 18:54:55.0000000000 +00:00 core
21 4096 Jun 15 2021 18:48:31.0000000000 +00:00 core/modules
22 0 Jun 15 2021 18:54:55.0000000000 +00:00 core/.callhome
23 4096 Jun 15 2021 19:16:10.0000000000 +00:00 .prst_sync
24 235 Dec 30 2021 11:05:27.0000000000 +00:00 .prst_sync/log
25 20 Dec 30 2021 11:06:51.0000000000 +00:00 .prst_sync/reload_history
26 4096 Jun 15 2021 18:48:31.0000000000 +00:00 .rollback_timer
27 4096 Jun 15 2021 18:48:38.0000000000 +00:00 gs_script
28 1024 Dec 30 2021 11:05:33.0000000000 +00:00 gs_script/sss
29 12288 Dec 30 2021 11:05:33.0000000000 +00:00 gs_script/sss/lost+found
30 5242880 Dec 30 2021 11:06:04.0000000000 +00:00 ssd
31 4096 Jun 15 2021 18:48:36.0000000000 +00:00 ss_disc
32 4096 Jun 15 2021 18:48:38.0000000000 +00:00 tech_support
33 15305 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/igmp-snooping.tcl
34 1612 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/igmpsn_dump.tcl
35 13515 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/mld-snooping.tcl
--More--   36 1612 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/mldsn_dump.tcl
37 15828 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/multicast.tcl
38 7367 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/multicast_dump.tcl
39 1330 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/pkt-drop-stats-dump.tcl
40 14047 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/pkt-drop-stats.tcl
41 1365 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-iid-ethernet.tcl
42 2107 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-iid-ipv4.tcl
43 2109 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-iid-ipv6.tcl
44 2729 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv4.tcl
45 2757 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv6.tcl
46 52363 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric-vrf-source.tcl
47 612 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform-fabric.tcl
--More--   48 1548 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/platform_evpn_vxlan.tcl
49 26175 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/port.tcl
50 3215 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/port_dump.tcl
51 18827 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/port_interface.tcl
52 8171 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/port_utils.tcl
53 15655 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/stack.tcl
54 4937 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/stackwise-virtual.tcl
55 1496 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/tech-support-confidential.tcl
56 685 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/tech-support-dump.tcl
57 38541 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/unicast.tcl
58 12653 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/unicast_dump.tcl
59 5162 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/unicast_ipv6.tcl
60 2864 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/unicast_ipv6_dump.tcl
61 336 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/utils.tcl
--More--   62 1384 Dec 30 2021 11:05:34.0000000000 +00:00 tech_support/xfsu.tcl
63 4096 Dec 30 2021 11:05:34.0000000000 +00:00 dc_profile_dir
64 251645 Dec 30 2021 11:05:34.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
65 251645 Jun 15 2021 19:15:20.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
66 395 Dec 30 2021 11:05:35.0000000000 +00:00 boothelper.log
67 4096 Jun 15 2021 18:48:39.0000000000 +00:00 sys_report
68 4096 Jun 15 2021 18:48:52.0000000000 +00:00 .USWAP
69 4096 Jun 15 2021 18:48:47.0000000000 +00:00 .USWAP/rp
70 4096 Jun 15 2021 18:48:52.0000000000 +00:00 .USWAP/fp
71 4096 Jun 15 2021 18:48:47.0000000000 +00:00 .CRFT
72 134458 Dec 30 2021 11:05:48.0000000000 +00:00 memleak.tcl
73 2049 Dec 30 2021 11:05:48.0000000000 +00:00 svl_ipc.tcl
74 4096 Jun 15 2021 18:48:48.0000000000 +00:00 Tbot
75 117906 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/HealthCheckDebugInfra.py
76 265373 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/L3ParseOutputs.py
77 365279 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/L3DebugInfraAPIs.py
78 155706 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/L2DebugInfraAPIs.py
79 164575 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/L2ParseOutputs.py
80 155706 Dec 30 2021 11:05:48.0000000000 +00:00 Tbot/L2DebugInfraScript.py
81 4096 Jun 15 2021 19:08:03.0000000000 +00:00 .dbpersist
--More--   82 4096 Jun 15 2021 19:08:03.0000000000 +00:00 .dbpersist/history
83 4096 Jun 15 2021 19:08:03.0000000000 +00:00 .dbpersist/DMI_STATE_DB
84 412 Jun 15 2021 19:08:03.0000000000 +00:00 .dbpersist/stats
85 13 Jun 15 2021 18:48:54.0000000000 +00:00 NVRAM
86 4096 Jun 15 2021 18:54:35.0000000000 +00:00 onep
87 4096 Jun 15 2021 18:54:35.0000000000 +00:00 onep/apps-cli
88 4096 Jun 15 2021 18:54:35.0000000000 +00:00 pnp-info
89 16976 Dec 30 2021 11:06:43.0000000000 +00:00 rdope_out.txt
90 4096 Jun 15 2021 18:54:38.0000000000 +00:00 guest-share
91 89 Dec 30 2021 11:06:41.0000000000 +00:00 rdope.log
92 0 Dec 30 2021 11:06:43.0000000000 +00:00 dope_hist
93 4096 Dec 30 2021 11:08:51.0000000000 +00:00 pnp-tech
94 15886 Dec 30 2021 11:08:51.0000000000 +00:00 pnp-tech/pnp-tech-time
95 181765 Dec 30 2021 11:08:51.0000000000 +00:00 pnp-tech/pnp-tech-discovery-summary
96 4096 Jun 15 2021 19:02:51.0000000000 +00:00 Apps
97 178872320 Jun 15 2021 19:03:01.0000000000 +00:00 Apps/thousandeyes-enterprise-agent-3.0.cat9k.tar
98 1440 Jun 15 2021 19:00:12.0000000000 +00:00 2021_06_15T18_59_57.875314.xml
9653563392 bytes available (1122914304 bytes used)
Switch#dir flash:
Directory of flash:/
106497 drwx 4096 Dec 30 2021 11:10:31 +00:00 .installer
114691 drwx 4096 Dec 30 2021 11:08:51 +00:00 pnp-tech
49155 -rw- 2097152 Dec 30 2021 11:06:53 +00:00 nvram_config_bkup
49154 -rw- 2097152 Dec 30 2021 11:06:53 +00:00 nvram_config
49176 -rw- 0 Dec 30 2021 11:06:43 +00:00 dope_hist
49173 -rw- 16976 Dec 30 2021 11:06:43 +00:00 rdope_out.txt
49175 -rw- 89 Dec 30 2021 11:06:41 +00:00 rdope.log
49169 -rw- 5242880 Dec 30 2021 11:06:04 +00:00 ssd
49172 -rwx 2049 Dec 30 2021 11:05:48 +00:00 svl_ipc.tcl
49171 -rw- 134458 Dec 30 2021 11:05:48 +00:00 memleak.tcl
49170 -rw- 395 Dec 30 2021 11:05:35 +00:00 boothelper.log
163872 drwx 4096 Dec 30 2021 11:05:34 +00:00 dc_profile_dir
49168 -rw- 185 Dec 30 2021 11:05:24 +00:00 bootloader_evt_handle.log
122881 drwx 4096 Jun 15 2021 19:16:10 +00:00 .prst_sync
106499 drwx 4096 Jun 15 2021 19:08:03 +00:00 .dbpersist
106504 drwx 4096 Jun 15 2021 19:02:51 +00:00 Apps
49178 -rw- 1440 Jun 15 2021 19:00:12 +00:00 2021_06_15T18_59_57.875314.xml
114689 drwx 4096 Jun 15 2021 18:54:55 +00:00 core
245761 drwx 4096 Jun 15 2021 18:54:38 +00:00 guest-share
--More--  237569 drwx 4096 Jun 15 2021 18:54:35 +00:00 pnp-info
221185 drwx 4096 Jun 15 2021 18:54:35 +00:00 onep
204801 drwx 4096 Jun 15 2021 18:48:48 +00:00 Tbot
163874 drwx 4096 Jun 15 2021 18:48:39 +00:00 sys_report
163841 drwx 4096 Jun 15 2021 18:48:38 +00:00 tech_support
122884 drwx 4096 Jun 15 2021 18:48:38 +00:00 gs_script
147457 drwx 4096 Jun 15 2021 18:48:36 +00:00 ss_disc
139265 drwx 4096 Jun 15 2021 18:48:31 +00:00 .rollback_timer
49167 -rw- 47364227 Jun 15 2021 18:46:14 +00:00 cat9k-rpboot.17.03.03.SPA.pkg
49166 -rw- 6802 Jun 15 2021 18:46:14 +00:00 packages.conf
49165 -rw- 9220 Jun 15 2021 18:46:14 +00:00 cat9k-wlc.17.03.03.SPA.pkg
49164 -rw- 14427140 Jun 15 2021 18:46:14 +00:00 cat9k-webui.17.03.03.SPA.pkg
49163 -rw- 28738568 Jun 15 2021 18:46:14 +00:00 cat9k-srdriver.17.03.03.SPA.pkg
49162 -rw- 57529348 Jun 15 2021 18:46:14 +00:00 cat9k-sipspa.17.03.03.SPA.pkg
49161 -rw- 34792456 Jun 15 2021 18:46:14 +00:00 cat9k-sipbase.17.03.03.SPA.pkg
49160 -rw- 595178500 Jun 15 2021 18:46:14 +00:00 cat9k-rpbase.17.03.03.SPA.pkg
--More--  49159 -rw- 5124 Jun 15 2021 18:46:14 +00:00 cat9k-lni.17.03.03.SPA.pkg
49158 -rw- 2262024 Jun 15 2021 18:46:14 +00:00 cat9k-guestshell.17.03.03.SPA.pkg
49157 -rw- 104428552 Jun 15 2021 18:46:14 +00:00 cat9k-espbase.17.03.03.SPA.pkg
49156 -rw- 17392652 Jun 15 2021 18:46:14 +00:00 cat9k-cc_srdriver.17.03.03.SPA.pkg
11353194496 bytes total (9653559296 bytes free)
Leo Laohoo
9200 will always have half the resources (CPU, memory and flash) than the more expensive units.
Leo,
Yeah, I can't believe the 9200 comes with only 4Gig of flash. This is 2022, and when it comes to memory and flash Cisco is still so stingy.
Reza
@Reza Sharifi wrote:
Yeah, I can't believe the 9200 3850 comes with only 4Gig of flash.
TFTFY.
9200 was meant to be a "re-badge" of the 3850 with.  The 9300 was meant to be called 3850-X (more memory and more CPU).
Instead of fixing the state &/or stability of the IOS-XE code, someone was paid a large sum of money to "renumber" platforms.
As a sign of how bad this is, Cisco can no longer maintain a decent collection of documentation.  It is now up to non-Cisco staff to knock up their own easy-to-understand and easy-to-read upgrade- and configuration guide, troubleshooting tips.  This is the sad state of affairs.
