02-29-2020 04:03 PM
I have a network that needs two cisco catalyst switches for HA requirements. The way I want the switches to operate are the way the Cisco ASAs work in active/standby. When one switch fails I want all traffic to pass through the "standby" switch. I am having trouble figuring out how to do this. I want to configure these through the ethernet ports, we are not using the stackwise options. Thanks!
02-29-2020 04:12 PM
02-29-2020 04:16 PM
02-29-2020 05:08 PM
03-02-2020 06:27 AM
I keep getting "Unrecognized Command" when I try to use the standby command while configuring my vlan. Is there other configuration that has to take place in order to enable this command on my switch?
03-02-2020 01:08 PM
03-03-2020 09:25 AM
So i was informed that by using HSRP or VRRP I would be implementing a layer 3 solution. I need to implement a failover solution at layer 2. We currently have active/standby ASAs on both sides of the switches. I want those switches to work in the same one, one switch passes all the traffic until it dies and then the second switch takes over. Is that possible from a layer two perspective?
