Cisco catalyst 9300 OOB port
daniel.tanch
Is it possible to connect cisco catalyst 9300 OOB port (G0/0) to the front panel data port (G1/0/1) within the same switch? And from the same switch there will be a trunk port to the firewall as the OOB gateway will be at the firewall. Reason being is that there is a lack of dedicated OOB switch.
Reza Sharifi
No, the OOB port (G0/0) is a host port and it should only connect to an OOB switch.
If you don't have an OOB switch, just use a vlan for in-band management.
Leo Laohoo
Then don't connect anything to the Management Port.
