Cisco Catalyst 9300 - Power-supply
I want to understand if Cisco Catalyst 9300 switches comes with a power supply option of 120V that is compatible with NEMA 5-15 receptacles ?
chrihussey
Yes. You can use the CAB-TA-NA power cable with the power supplies.
Hope this helps.
Reza Sharifi
NEMA 5-15 is the default power cord that comes with the switch when you order it for North America.
