Cisco Catalyst 9300 WiFi controller ???
Jookez
Good day. I am using a Cisco Catalyst 9300, I would like to add a WiFi controller function. What I need to install and purchase. Please tell me. Thank you in advance.
Scott Hodgdon
Jookez,
At this point in time, we only support embedded wireless controller (eWLC) function in Catalyst 9000 family switches when those switches are part of a Cisco SD-Access architecture. If you are not deploying SD-Access, then you cannot enable the eWLC function in the switch.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
Scott - is this still valid? I mean if we can enable WLC functionality on the Cat9300 without SD-Access architecture?
I will be appreciated your answer.
You can from 17.3.1
Can you confirm that WiFi is a functionnality inside a 9300 ?
This week, I also plan to check if this functionnality is available; but the the goal is to disable it !
 (of course)
