Cisco catalyst c3560-8pc-s switch Rebooting problem
haristufail
Hi everyone. i have Cisco C3560-8pc-s switch. which is Rebooting. kindely any body tell me what is the problem.
and how to resolve the problem.
thanks in advance.
Leo Laohoo
Software is crashing the appliance.  I'd recommend you upgrade the IOS via ROMmon.
Thanks for ur suggestion. I will try.
I would say replace this device as it seems a hardware failure. I could see that Post is failing as below.
POST: PortASIC CAM Subsystem Tests : Begin
HTD POST: Basic Test Failed
POST: POST Failed
POST: PortASIC CAM Subsystem Tests : End, Status Failed
POST: CAM test failed
POST Failed: disabling stack links and shutting down SDP
Hope this helps.
***Plesae rate all useful posts*******
