Cisco Catalyst vs Nexus switches
ssethu_dce
what is the difference between cisco catalyst and nexus switches?
Cisco Nexus and SAN Switches both are same?
Cisco MDS and SAN Switches both are same?
6 Replies 6
Reza Sharifi
Cisco catalyst switches are mainly designed for distro/core layers in campus network vs the Nexus is mainly for data centers.  Nexus series switches can support Ethernet, Fiber Channel and FCOE all in the same chassis but the catalyst don't. The catalyst switches support only Ethernet.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"The catalyst switches support only Ethernet."
Actually, the 6500 series can support serial WAN connections using a FlexWAN card.
The 6500 series can also provide other special functions, via services module line cards, such as firewall, VPN, network analysis, etc. (see http://www.cisco.com/c/en/us/products/interfaces-modules/services-modules/index.html), unavailable on the Nexus.
The Nexus offers more bandwidth capacity (although the 6500s have somewhat narrowed the gap with the sup2T) and the Nexus had its FEXs (but 6500s have narrowed this too with the new IAs.)
As Reza notes, the Nexus is oriented for large data centers while the 6500 (and subsequent 6800) series are for more "generic" L3 switching, for LAN core, distro, and host edge.  (NB: although the 6500 series can do some MAN and WAN, its "router" sibling, the 7600 series, is more oriented for that.)
InayathUlla Sharieff
Answer:-Reza already said this. Catalyst are very good for dist/core and Nexus are mainly for Data Center
Answer: No they are not. (SAn switches are like MDS etc..)
3)
Answer: Yes.
Inayath
***********plz dont forget to rate if this info is helpfull**********
Configuration & command wise any difference is there between catalyst and nexus switches?
Yes certainly but not completely.
Some ref:
http://www.cisco.com/c/dam/en/us/products/collateral/switches/nexus-7000-series-switches/C07-572833-00_NX-OS_CLI.pdf
Inayath
*****please dont forget to rate all usefull posts.
Hello Inayath,
Can I connect a core switch ws-c4510r+e against a nexus N2K-C2232TM-E ?
Best regars,
Tello.
