VRF Routing
UniWAQ
Hallo All ,
I am not not able to ping from vrf to external networks , anyone could guide me.
vrf definition lan
address-family ipv4
exit-address-family
vrf definition prov-pri
address-family ipv4
exit-address-family
vrf definition prov-sec
address-family ipv4
exit-address-family
interface FastEthernet0/0
vrf forwarding prov-pri
ip address 13.13.13.1 255.255.255.0
duplex full
interface FastEthernet1/0
vrf forwarding prov-sec
ip address 12.12.12.1 255.255.255.0
duplex full
interface FastEthernet2/0
vrf forwarding lan
no ip address
speed auto
duplex auto
interface FastEthernet2/0.100
encapsulation dot1Q 100
vrf forwarding lan
ip address 192.168.100.1 255.255.255.0
interface FastEthernet2/0.200
encapsulation dot1Q 200
vrf forwarding lan
ip address 192.168.200.1 255.255.255.0
R1# show ip vrf
Name Default RD Interfaces
lan <not set> Fa2/0
Fa2/0.100
Fa2/0.200
prov-pri <not set> Fa0/0
prov-sec <not set> Fa1/0
R1#show ip int brief
FastEthernet0/0 13.13.13.1 YES manual up up
FastEthernet1/0 12.12.12.1 YES manual up up
FastEthernet2/0 unassigned YES unset up up
FastEthernet2/0.100 192.168.100.1 YES manual up up
FastEthernet2/0.200 192.168.200.1 YES manual up up
FastEthernet2/1 unassigned YES unset administratively down down
R1#show run | sec ip rotue
R1#show run | sec ip route
ip route vrf lan 0.0.0.0 0.0.0.0 FastEthernet0/0 13.13.13.3
ip route vrf lan 0.0.0.0 0.0.0.0 FastEthernet1/0 12.12.12.2 20
ip route vrf lan 13.13.13.1 255.255.255.255 FastEthernet0/0 13.13.13.3
ip route vrf prov-pri 0.0.0.0 0.0.0.0 13.13.13.3
ip route vrf prov-sec 0.0.0.0 0.0.0.0 12.12.12.2
R1#show run | sec ip router
R1#show run | sec router
router eigrp 100
network 192.168.100.0
network 192.168.200.0
R1#
R1#ping vrf prov-pri 13.13.13.3 source fast
R1#ping vrf prov-pri 13.13.13.3 source fastEthernet 2/0.100
Sending 5, 100-byte ICMP Echos to 13.13.13.3, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.1
Success rate is 0 percent (0/5)
R1#ping vrf prov-pri 13.13.13.3 source fastEthernet 2/0.200
Packet sent with a source address of 192.168.200.1
R1#ping vrf lan 192.168.100.254
Sending 5, 100-byte ICMP Echos to 192.168.100.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/7/32 ms
R1#ping vrf lan 192.168.200.254
Sending 5, 100-byte ICMP Echos to 192.168.200.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/15/40 ms
R1#ping vrf prov-pri 4.4.4.4
Sending 5, 100-byte ICMP Echos to 4.4.4.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/64/120 ms
R1#ping vrf prov-sec 4.4.4.4
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/52/68 ms
R1#
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/27/36 ms
R1#ping vrf prov-pri 13.13.13.1
Sending 5, 100-byte ICMP Echos to 13.13.13.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R1#ping vrf prov-sec 12.12.12.1
Sending 5, 100-byte ICMP Echos to 12.12.12.1, timeout is 2 seconds:
R1#ping vrf prov-sec 12.12.12.2
Sending 5, 100-byte ICMP Echos to 12.12.12.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/21/36 ms
R1#ping vrf lan 13.13.13.1
R1#ping vrf lan 13.13.13.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/80/136 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/71/96 ms
R1#
With Regards
Julio E. Moisa
It will not able to communicate because they are on different VRF instances, separated routing tables:
duplex full
vrf forwarding lan
It could communicate between each other if you are importing the subnets into each others, currently they should not have the prefixes entries into their routing tables.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
johnd2310
Level 8
Level 8
What does you topology look like? Where are these addresses: 13.13.13.3, 12.12.12.2
John
**Please rate posts you find helpful**
