07-30-2024 04:41 AM
Hi i have the following issue
I want to connect a pair of Nexus Switches (Both operate together with VPC to enable redundancy) to a VSS-Stack of two Catalyst switches. How do i need to connect them together? Each to each with one Port-Channel per Switch? Or just each Nexus to the Stack? Is there somekind of Graphic that explains how you can establish such a connection between two switches?
07-30-2024 05:16 AM
M.
07-30-2024 06:45 AM
Have a look at this post with diagrams and explanations.
https://community.cisco.com/t5/switching/vss-core-and-vpc-distrubution/td-p/3064758
