Cisco Catalyst WS-C2960L-24TS-LL - No IP and WebUI
Hiddai
Cisco Hi,
Unfortunately, I tried to reset my device through the configuration CLI tab in IOS-WebUI and I ruined it.
Now, I see no IP (no 10.0.0.1 or the IP the device got from DHCP).
Also, I can't browse to it's IOS WebUI.
Please, help me to recover the device.
Guide me to the simplest way to recover it (anyway, I'm junior).
I have a RJ45-USB console cable.
Thanks!
First change the Boot variable to boot correctly :
you need to change 2 config here
1 is boot variable :
config t
no boot system
boot system flash:/c2960l-universalk9-mz.152-6.E2b/c2960l-universalk9-mz.152-6.E2b.bin
end
wr
2nd config reg
config t
confreg 0x2102
end
wr
and reload the device.
Once the device reloaded - you can setup the switch as normal, if you like GUI, then you need to configure your PC with IP 10.0.0.2 gateway 10.0.0.1 (ping 10.0.0.1 - if that work, you can use GUI to configure) - make sure you setup username and passswor.
BB
17 Replies 17
marce1000
 https://www.cisco.com/c/dam/m/en_sg/cisco-start/assets/pdfs/Cisco_Catalyst_2960-L_Easy_Setup_Guide_20161105.pdf
 M.
Thanks. But I already reviewed this article and as I already mentioned I lost 10.0.0.1 address
Reza Sharifi
Can you use the console cable and connect to the switch and post the output?
attached bootlog.txt file
balaji.bandi
I have a RJ45-USB console cable. - connect the console cable to the device and post complete bootlogs here to understand the issue.
BB
Are you booting the switch Manually?
switch: boot
Loading "c2960l-universalk9-mz.152-6.E2b"...
Error loading "c2960l-universalk9-mz.152-6.E2b"
Interrupt within 5 seconds to abort boot process.
..................................................Loading "flash:/c2960l-universalk9-mz.152-6.E2b/c2960l-universalk9-mz.152-6.E2b.bin"...Verifying image flash:/c2960l-universalk9-mz.152-6.E2b/c2960l-universalk9-mz.152-6.E2b.bin...........................................................................................................................................................................................................................................
Image passed digital signature verification
File "flash:/c2960l-universalk9-mz.152-6.E2b/c2960l-universalk9-mz.152-6.E2b.bin" uncompressed and installed, entry point: 0x3000
executing...
BB
Hello
From the switch prompt run the commands below and post them into a txt file and attached to this post
switch> enable
show version
show boot
show run
dir flash:
Kind Regards
Paul
attached additional file :)
Yes.
I'm sorry.
I understand the following request: "...and post complete bootlogs" - as to perform it manually
config t
no boot system
end
wr
2nd config reg
config t
confreg 0x2102
end
wr
BB
since I have no experience with that:
Before I start performing your instructions:
1) to perform the instruction, in what state I should load the switch now?
- press on mode button then connect with putty? (the following line is displayed: "switch#")
OR
- start as usual, just turn on the switch and connect via putty? (the following line is displayed: "switch>")
2) after performing your instructions:
In order to connect to the switch that configured with IP: 10.0.0.1 via web browser -
Should I configure the PC IP to 10.0.0.X?
To perform the task you need to get in to enable mode
> enable
you get hash prompt. ( you can copy and paste my commands)
you can reload the device, configure your PC with 10.0.0.X (2-254) with the gateway 10.0.0.1 then you use browser to configure.
BB
confreg 0x2102 and config-register 0x2102 commands show "Invalid input detected at '^' marker"
How can I take over this issue please?
