Cisco Catalyst WS-C2960L-24TS-LL - No IP and WebUI
Hiddai
Cisco Hi,
Unfortunately, I tried to reset my device through the configuration CLI tab in IOS-WebUI and I ruined it.
Now, I see no IP (no 10.0.0.1 or the IP the device got from DHCP).
Also, I can't browse to it's IOS WebUI.
Please, help me to recover the device.
Guide me to the simplest way to recover it (anyway, I'm junior).
I have a RJ45-USB console cable.
Thanks!
17 Replies 17
it should be done in configuration mode
post complete command entered in the console logs.
BB
Thanks bandi.
I'll stop here, since after reload the switch and connecting to 10.0.0.1 - the WebUI is loaded properly.
Hello
The switch does have an ip address allocated to it, but it doesn’t have a default-gateway so you wont be to remote access this switch unless you are on the same subnet as the switch.
You could do one of two things:
1) Make the switch a dhcp client
conf t
interface vlan 1
ip address dhcp
or
2) assign the switch a default-gateway <  this will be the ip address of the device perfroming the routing vlan vlan 1
conf t
ip default-gateway 10.0.0.X
Kind Regards
Paul
