Cisco CBS350-16XTS Stack problem
telekopole
Community Member
In our company, we have two Cisco CBS350-16XTS devices configured in a stack. For some time now, we've been experiencing issues with one of the units.
A month ago, the first failure occurred with Unit 1, which was acting as the master. The logs only showed information related to a critical system error.
Logs:
%STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0x9de signal-num = 8 (SIGFPE) signal-code = -6 (Unknow n) reg[00] = 0x0 reg[01] = 0x4ce5eef8 reg[02] = 0x0 reg[03] = 0x8 reg[04] = 0x8 reg[05] = 0x0 reg[06] = 0x0 reg[07] = 0xaf reg[08] = 0x0 reg[09] = 0 x4ce5fb18 reg[10] = 0x0 FP = 0x0 IP = 0x0 SP = 0x4ce5eef8 LR = 0x4ce5eef8 PC = 0xb6f62fa8 CPSR = 0x40010 Fault Address = 0x0 Trap no = 0x0 Err Code = 0x0 Old Mask = 0x0 ***** FATAL ERROR *****
Reporting Task: STSB. Software Version: 3.4.0.17 (date Nov 29 2023 time 17:16:50) base_address=0x004b0000 ro
After restarting, Unit 1 functioned normally for a month. However, it recently failed again, and this time it started rebooting in a loop.
Logs:
2142147465069 2024-Oct-01 09:55:54 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465089 2024-Oct-01 09:53:10 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465109 2024-Oct-01 09:50:26 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465129 2024-Oct-01 09:47:41 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465149 2024-Oct-01 09:44:57 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465169 2024-Oct-01 09:42:12 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465189 2024-Oct-01 09:39:28 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465209 2024-Oct-01 09:36:44 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465236 2024-Oct-01 09:33:59 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465267 2024-Oct-01 09:31:15 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465294 2024-Oct-01 09:28:31 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
2147465396 2024-Oct-01 09:25:47 Error %Stack-E-STCK-EXCEP-HNDLR: Lost connection with unit 1 reason : connection timeout. Unit will be rebooted .
Could you please advise on how we can resolve the issue with Unit 1 in our stack?
Mark Elsen
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwk48203
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
