cisco Cisco 9300-48P can be stacked with 9300-48U
Ditter
Level 4
Level 4
Hi to all,
is there the capability of stacking together 9300-48P with 9300-48U?
And if yes what happens in case you implement power stacking?  Should both have 1100WAC or the 9300-48P could go with the standard 715WAC?
I suppose it has to do with power budgeting but if you have poe devices @ 60W you should gather them together to the 9300-48U and all at & af devices to the second 9300-48P.
All of these assumptions only in the case they can be stacked together but can they?
Ditter.
